05-16-2017, 01:49 PM
#141
1966 22' Safari
1954 22' Flying Cloud
Saline
, Michigan
A little more work done in the front[ATTACH]
05-22-2017, 06:35 AM
#142
1954 25' Cruiser
Upstate SC
, South Carolina
Originally Posted by goshawks00
Thanks, I hear folks talk about rear hold down plates but our Cloud has a rear hatch so I guess there wasn't a rear hold down plate there. I did get two coats of sealer on the one side of the wood but rain is slowing me down. Luckily I have a garage I can paint in so they are all on saw horses getting their licks. I was able to talk to Steve at VTS today and ordered three new tanks, got a great deal from him, just hoping to get them quickly. No word on the axle yet though. Next is finding an umbilical cord and figure out what material for the belly pan and the under the frame tire rack box.
Which model number/size tanks did you decide on?
05-22-2017, 09:29 PM
#143
1966 22' Safari
Saline
, Michigan
We used three VTS 747 tanks. One for fresh water, two for grey water
05-26-2017, 04:17 PM
#144
1966 22' Safari
Saline
, Michigan
Making baby steps, but still moving forward [ATTACH]
06-30-2017, 04:19 PM
#145
1966 22' Safari
Saline
, Michigan
A Cloud named 'Spoon'
Finally moving again Spoon has her new marmoleum floor in. A tip for you diyers- use your electric metal shears to cut the flooring, works like butter.[ATTACH]
06-30-2017, 05:58 PM
#146
1950 Flying Cloud 7039
1950 21' Flying Cloud
Allen
Is the wood plywood? I tried some thing with veneer and found that the is just to much movement in wood.
06-30-2017, 06:28 PM
#147
1966 22' Safari
Saline
, Michigan
Yes 1/8" three ply birch
07-25-2017, 05:39 PM
#148
1966 22' Safari
Saline
, Michigan
09-27-2017, 10:06 AM
#149
1966 22' Safari
Saline
, Michigan
Been a while so a quick photo op of where we're at. Fridge is roughed in, vintage door for it is in process. Toilet is in,vents for both grey water tanks ran. Wiring is in but still not finished. Most of the wood is done. Camping and life keeps getting in the way. Attachment 290479Attachment 290480Attachment 290481
After a long wait, our taillights are back from the chrome plater and I hope to have them installed tomorrow . I got to say they look amazing![ATTACH]295672
09-27-2017, 10:37 PM
#150
1966 22' Safari
Saline
, Michigan
One down one to go[ATTACH]
09-28-2017, 07:17 AM
#151
1966 22' Safari
Fredericksburg
Everything is really looking good. You're making great progress. I'm interested in your new fridge and your plan to retrofit a vintage door. We plan on doing the same. I came across a mid 50's Dometic last year and removed the door. Now I need to find a modern fridge and figure out the retrofit particulars. I would be very interested in the details on how it's attached when you get to that point. Thanks, Bubba
09-28-2017, 11:12 AM
#152
1966 22' Safari
Saline
, Michigan
one down one to go[attach]
[attach]
09-28-2017, 11:20 AM
#153
1966 22' Safari
Saline
, Michigan
Ok Bubba here is the down and dirt. This is the door face I'll be using front and back pictures. The new refrigerator door will fit inside of the vintage face it will be attached somehow bolted to the backside of the face so they both look like it's one piece I will post when it's done I hope that's clear as mud[ATTACH]295744[ATTACH]295745
10-13-2017, 06:56 PM
#154
1966 22' Safari
Saline
, Michigan
Finally have all the window trim finished, except the window next to the door. I needed to install some type of emergency cable for the door FOB in case of electrical failure then i can start on interior
10-15-2017, 11:38 AM
#155
1966 22' Safari
Saline
, Michigan
10-17-2017, 10:01 AM
#156
1966 22' Safari
Saline
, Michigan
So had time to make up the emergency pull system in case the FOB had a power failure. One line goes down the wall through the belly pan, and the other goes parallel into the storage area which will be in back of the couch.
10-17-2017, 11:57 AM
#157
1966 22' Safari
Saline
, Michigan
10-17-2017, 11:59 AM
#158
1966 22' Safari
Saline
, Michigan
Was also able to finish the fan and front wood piece. The will be a light in front of the fan,( the wiring is already there in back of the wood piece) but we haven't found the right light yet.
10-27-2017, 10:51 AM
#159
1966 22' Safari
Saline
, Michigan
We have rounded the corner so to speak. The bed frame is sitting where it will go so I can begin to make the night stands. Of course the misses needs to make the bed, to see how it looks!
10-27-2017, 10:52 AM
#160
1966 22' Safari
Saline
, Michigan
