Old 04-07-2017, 12:57 PM   #127
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
Slowly moving forward, the wiring in the front is roughed in, the cork rib insulation for thermal separation is done. The front cap is finally up, so I'll begin to make patterns for the wood end caps. Feel like I'm beginning to round a corner.Click image for larger version
goshawks00 is offline   Reply With Quote
Old 04-11-2017, 12:17 PM   #128
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
ID:	283165first rough in for front end cap
Old 04-11-2017, 01:16 PM   #129
On adventure with H&G
MattB's Avatar
2012 30' Flying Cloud
1966 28' Ambassador
Lansing , Kansas
That looks fantastic. What type of wood are you using?
MattB is offline   Reply With Quote
Old 04-12-2017, 06:29 AM   #130
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
I'm using 1/8" Baltic birch , the whole interior will be wrapped in it. BYW glad to see you back at it!
Old 05-01-2017, 06:46 PM   #131
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
We finally got the rear interior whale tail panel hung now to Mach up the panels. The front wood cap is all up with two coats of varnish, will try and get a pic tomorrow. It's been hard to get much done with spring here. Gardens, grass, camping etc then a little each day on Spoon.Click image for larger version
Old 05-02-2017, 04:30 PM   #132
1971 27' Overlander
Jackson , Tennessee
Enjoying following your progress - great work!
Where did you find the 1/8" Birch? I'm having trouble locating a source.
Alan
TennTex is offline   Reply With Quote
Old 05-02-2017, 07:43 PM   #133
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Johnsons in Charlotte
Old 05-03-2017, 11:48 AM   #134
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Front end cap done , I like the wood grain!Click image for larger version
ID:	284644Click image for larger version
Old 05-04-2017, 12:28 AM   #135
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Slowly rough fitting the rear woodClick image for larger version
Old 05-04-2017, 09:01 AM   #136
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 21
Birch end panels
Really like the birch panels. How are you attaching them on the long edge? Last photo looks like there is a liner underneath. Details please.
thanks Harold
57Vintage is offline   Reply With Quote
Old 05-04-2017, 01:16 PM   #137
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
I put the original metal end caps back in as it gave good support for the wood panels where ever they lined up at. I attached the upper side of each piece with just a couple of rivets to hold in place while I fitted/adjusted the next piece., working from the bottom up. Once all pieces were fitted and in place, I took them apart, and put three coats of spar on the backs, stained the fronts and added two coats on them. Once completely done they, the insides, will get one more final coat. Once dried I re-aligned each piece, and as I worked my way up, where the bottom edge of the upper over lapped the upper edge of the bottom piece below it, I drilled and riveted the overlap every 5" 3/8 ' in from the edge. Clear as mud?
Old 05-04-2017, 02:23 PM   #138
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
That was 3/8" from the edge. , and I used 5/32" pop rivets.
Old 05-04-2017, 03:30 PM   #139
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
A Cloud named 'Spoon'
Kind gives a nice neat finishClick image for larger version
Old 05-08-2017, 01:42 PM   #140
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
After a bunch of fitting -staining-and varnishing the bedroom area is done.[ATTACH]
