Old 06-03-2013, 11:55 PM   #85
riv-nut's Avatar
1952 21' Flying Cloud
renton , seattle area
Images: 24
Originally Posted by 54breadloaf View Post
Lee,
Top notch work, my friend! Wish you were with me when I did mine. You seem to have some great ideas. Keep it up. It will be interesting to see your progress.
JT
Hey JT....good to hear from you!! I haven't seen pictures of your project in a while. So you got the floor down and the shell back on after the Albuquerque trip eh?? Progress has been a bit slow on mine. Partially the weather, and partially me being nervous about the belly pan :-)
I'll post some picture of the rotisserie set-up once I verify that it works ...how embarrassing would that be to show some slick system only to have it fall apart and screw up my trailer!! I've also been getting ready to dig into the gas stove. I think I can get it all cleaned up and functional without too much effort. Maybe some new insulation and paint inside, but it's pretty clean overall and hopefully the plumbing works!! Here's a couple pictures of it...
Lee
ID:	187387   Click image for larger version
riv-nut is offline   Reply With Quote
Old 06-04-2013, 10:07 AM   #86
54breadloaf's Avatar
1954 22' Flying Cloud
Escondido , California
Hey Lee,
Great stove! Mine came with a Majic Chef smaller one that you have probably seen in other trailers. I won't use it as I plan on modernizing the interior of my trailer. For now, I'm just doing odd jobs like rebuilding the storage access doors, windows, entry door, etc. while waiting for Uwe to have enough time for the belly pans. I really wanted to pull the Breadloaf to Oregon this July but looks like it will have to be next year. Oh, I did buy some new wheels and hubcaps from VTS. I hope to get new tires as well.
54breadloaf is offline   Reply With Quote
Old 06-07-2013, 08:52 AM   #87
riv-nut's Avatar
Images: 24
Looks good JT!
Hopefully Uwe can get to your belly pan soon!! I like your wheels...I found a pair for a 50's chevy truck on craigslist an had them powder coated. They look great, but I still need to find some hub caps like yours.
So, yesterday I got the frame flipped over so I can screw down the insulation boards and put on the belly pan! Wow are these things heavy....it was a nail-biter all the way! I hope re-flipping it goes just as well .
Here's some pictures of how I did it. The fitting bolted to the back bumper should look familiar...I borrowed the piece from my old engine stand. In the front I welded a piece of angle that fit nicely between the frame rails to a pipe and drilled a hole to bolt on a ball (also used an extra piece of all-thread through the tongue jack hole to make sure the ball would slip out of the hitch when inverted). Look out belly pan here I come!!!
Lee
ID:	187648   Click image for larger version
ID:	187650   Click image for larger version
ID:	187652   Click image for larger version
Old 06-07-2013, 04:15 PM   #88
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Great idea Lee, I love the engine stand on the back, and will incorporate it in my lift. Thanks!!. Am I correct to think the bar in the tube in the front, has a nut welded to it and that the ball shaft goes into the hole in the tube and screws into the nut? I like that idea and our garage has two beams that I can run the two chain falls from... I did hear from the axle co. and the axle is ready, so will be picking it up Mon.
BTW looks great nice Mc Guyver move!!
goshawks00 is offline   Reply With Quote
Old 06-08-2013, 12:23 AM   #89
riv-nut's Avatar
Images: 24
Barry...you're good...real good. Everything you described above is exactly right.... Yes, nut welded to the bar that goes in the end of the pipe. This would've been much easier with a chain hoist at each end as you mentioned you have. I had to build a wooden pivot support at the front which you won't have to! Got all the insulation installed and the two middle belly pans trimmed around the axle. Glad to hear your axle is ready!!! Keep up the great work!
Lee
Old 06-08-2013, 02:16 PM   #90
Lee,
You are a fricken genius! It's really looking great man. Can't wait to watch your progress.
JT
Old 06-12-2013, 11:34 PM   #91
riv-nut's Avatar
Images: 24
Lee,
JT
LOL...thanks JT - you're giving me way more credit than I deserve...that's for sure! Been making a little progress. Got all the insulation installed and some good belly pan progress in between rain showers. I'd post pictures, but I guess my allowable drive space is full. I wonder if there's any way to compress all the pictures I've posted. Can't just delete them since all the pictures of my progress would be gone.....hmmm.
Old 06-13-2013, 12:52 AM   #92
riv-nut's Avatar
Images: 24
Hmm...well, since I guess I'm out of space on AirForums for pictures, I tried out the google picasa web photo album thingy. Let me know if you can see my pictures??? Near the end you can see the insulation installed and some of the bellypan forming efforts....
Lee
https://picasaweb.google.com/1126314...55365210592402
Old 06-13-2013, 05:23 AM   #93
Lee
Wow! What a luxury to be able to flip that trailer. Everything looks so clean and well thought out, Lee. Very nice.
JT
Old 06-21-2013, 12:53 AM   #94
riv-nut's Avatar
Images: 24
Thanks JT! Yes, I can't imagine doing the insulation and the belly pan lying on my back!!
Anyway, got the pan cut trimmed and installed!! And flipped it back over. I think it came out great....maybe not perfect, but would do it the same way again if I had to. Here's a couple pictures...
Old 06-21-2013, 01:56 AM   #95
riv-nut's Avatar
Images: 24
If those pictures didn't come through, I uploaded all of them to the picasa website again:
https://picasaweb.google.com/112631417500634212784/BellyPan#
Old 06-21-2013, 05:05 AM   #96
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Lee all I get is "Sorry that page not found".
Old 06-21-2013, 01:08 PM   #97
riv-nut's Avatar
Images: 24
okay - sorry about that....I forgot to "share it"! Try it again....
Old 06-21-2013, 03:48 PM   #98
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Nope ...no go ;>(
Want me to lend ya twenty bucks so you can join us ?
flying cloud
