Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum
Old 04-18-2004, 05:49 PM   #1
Profile:  Whitehorse , Alaska
year wood veneer changed to laminate? thx
Hi, Does anybody know in what year airstream started using plastic laminate instead of real wood veneer and solid wood combo's in the interiors? I know there is always some wood, but it looks as if in 1971, there was a big switch to plastic laminate, especially in the kitchen. Am I correct in the year, '71? And was this for all models, or was it phased in over a number of years for different models? Did they switch back to real wood at some point? I am looking to buy and do want a real wood interior. So far I am asking each seller, and deciphering through examining photographs. Thanks a lot for any help. Merci. Susie Rogan, Yukon Territory, Canada
yukonsilver is offline   Reply With Quote
Old 04-18-2004, 05:57 PM   #2
85MH325's Avatar
Profile:  Tipton , Iowa
Images: 37
'71 was the year
As far as I know, '70 was the last year for the wood veneer, across the line.
Roger
AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein
1994 Airstream B190 & 2006 Bigfoot 25B25RQ
Old 04-18-2004, 06:00 PM   #3
Thumbs up roger that
Thanks Roger.
Old 04-18-2004, 06:28 PM   #4
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Thumbs up I agree...
'71 was the first year the cabinets switched over to plastic laminate. So if you want "real wood" in a vintage unit, stick with the pre-'71s
You may want to check out the Vintage Comparison Matrix located on our website in the "Links & Resources" section.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 04-18-2004, 06:31 PM   #5
silverlassie's Avatar
Profile:
Susie,
We have a '69 Landyacht with what I believe to be mahogany, cherry? not sure but it is beautiful!. The wood was in need of some TLC when we bought it. I put some Minwax Antique Oil on it, hand buffed it and it came back to life. As Roger said it will be no more and along with the other unique aspects of Airstreams is just an added beauty. You won't regret your decision on this one.
Mindy
silverlassie is offline   Reply With Quote
CCD Wood Veneer Dinette - Update joshua32064 Cabinets, Counter Tops & Furnishings 10 04-21-2005 04:44 PM
Wood veneer type Silver Bullet Cabinets, Counter Tops & Furnishings 7 03-25-2004 07:46 PM
Original wood grain laminate (74) AV8 Upholstery, Blinds, Walls & Interior Finishes 1 01-19-2004 09:33 AM
Wood Veneer Dinette Bench joshua32064 Cabinets, Counter Tops & Furnishings 17 10-08-2003 02:03 AM
Wood Veneer Furniture Project joshua32064 Cabinets, Counter Tops & Furnishings 5 10-05-2003 01:52 AM
