Old 07-10-2016, 02:23 PM   #1
merino , Colorado
Wood end caps---overlander
We are in the process of replacing the end caps with wood on our overlander. Any tips would be so much appreciated!
MissBeeHaven is offline   Reply With Quote
Old 07-10-2016, 02:41 PM   #2
mandolindave's Avatar
It sounds like it will look great.
But if you get a leak, you'll have to double back, and do it again. AND trying to match your previous wood color and patina might be a PITA.
mandolindave is offline   Reply With Quote
Old 07-10-2016, 03:02 PM   #3
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
If you have no idea on how or where to start, don't do it.......and I'm a cabinetmaker.
Trying to explain compound curves, expansion, contraction allowances to a lay person would be like trying to explain Quattum Physics to me. It one of those things that can be very difficult, if not impossible to explain.
If you can wrap a balloon with wood, you are good to go.
Cheers
Tony
Old 07-10-2016, 03:09 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I take the other approach, just do it and learn as you go.
That is what I did.
Now, not to say that I won't do it different when I do it again, but I am satisfied with my results.
For me the biggest part of understanding the whole process is accepting that the wood will only bend on one plain.
I used 16 gauge sheet metal to join the panels together and then used stringers to cover the seams. I used 9 panels.
http://i245.photobucket.com/albums/g...psl10ph80u.jpg
Superat stultitia.
« '73 v '90 | Top | Mouse Fur »
Is this the end of my end caps? unit13 Upholstery, Blinds, Walls & Interior Finishes 9 01-02-2017 10:42 AM
1970 overlander interior end caps fullahotair Airstream Classifieds 0 06-04-2016 08:24 AM
Wood End Caps tweetie1966 Upholstery, Blinds, Walls & Interior Finishes 5 12-01-2014 02:48 PM
Wood end caps Canlib General Interior Topics 5 09-11-2010 11:45 AM
What kind of interior paint 1971 Overlander/End caps dingy riverdreamer Upholstery, Blinds, Walls & Interior Finishes 5 05-24-2004 09:36 AM
