Old 08-20-2013, 09:58 PM   #1
Skinned knuckles
Sychedelia's Avatar
1963 19' Globetrotter
Auburn , California
Window trim question '63 GT
I am early in the renovation of a 63 globetrotter. I am doing a frame off restoration and I'm starting the interior skin removal. I took the interior window trim off in order to get the lower panels off. Eventually, I want to have shiny aluminum interior window trim. The trim is coated in multiple layers of paint. I searched for window trim replacement in order to find out whether not I should ultimately try to strip and polish the existing trim or plan on replacing it completely. I'm concerned that refinishing them would be pretty tough because of the condition and the chance of bending or damaging them. They are just simple mitered 90 degree trim pieces of aluminum sheet. Are they available commercially or would they be simple to fabricate ? Any insight would be appreciated
Sychedelia is offline   Reply With Quote
Old 08-21-2013, 02:41 PM   #2
flygrrl
flygrrl's Avatar
1962 19' Globetrotter
Winchester , Ontario
trimming it out
Looks like those would be pretty simple to fabricate. Do not throw them out!! I am pretty lucky my local hardware store has a large break and let folks use it (good customers like me) so ask around. Also local seamless gutter/soffit/fascia guys would prob.fabricate them for you on the weekend as an aside-type of job for beer money, again, ask around. That being said, soaking in some good quality green paint stripper and a bit of gentle scraping and buffing may just do the trick.
TV: 2007 Jeep GC Laredo diesel
Toy: 1995 Jeep YJ
Experience is what you get from not having it when you needed it.
flygrrl is offline   Reply With Quote
Old 08-21-2013, 04:20 PM   #3
65CV's Avatar
Western , Massachusetts
I'm not a big fan of Harbor Freight, but their bending brake has saved me a few bucks.
See this
That said, your trim is pretty resilient and it's a bit of work to duplicate.
Stripping paint from them isn't fun and is quite time consuming.
For a source of aluminum, many of us use airpartsinc.
Good luck. '63 Globetrotters are great trailers!
65CV is offline   Reply With Quote
Old 08-21-2013, 04:26 PM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I'd strip them. By the time you spend time researching and money trying to find something else that will work...you can have them stripped.
As far a bending them while polishing, use clecos to hold them to a 2x4 - that way they aren't as flimsy. Move the clecos as you work an area...similar to what we did here (1st pic) with side panels. Just lay the trim over the corner of the 2x4 then drill where the holes are and put a cleco in it.
Shari
Old 08-21-2013, 10:50 PM   #5
mapleton , Utah
Shari, that is BRILLIANT. thank you
tim
rumrunner is offline   Reply With Quote
Old 08-21-2013, 11:27 PM   #6
Skinned knuckles
Sychedelia's Avatar
Auburn , California
Thanks, great ideas. I removed them all today with the lower interior skins. I labeled them all and will plan on refinishing them. I appreciate the info on the bending brake. I will probably fabricate new upper trim if I can get the finish to match. The upper frames have the extra pop rivet holes that held the curtain slider. I will be using shades or blinds and would prefer a matching trim.
The cleco and 2X4 trick is going to really help with the refinishing. I am going to put that off for now as I work towards separating my frame from the shell. I am planning to build a gantry system and lifting from above to separate. Wish me luck.
Here are a few pics of the progress so far.
ID:	193802   Click image for larger version
Old 08-22-2013, 04:04 AM   #7
Baltimore , Maryland
I would just make new ones. In the time you would strip just one window you could make all new. It is a very easy thing to make. 1 1/2" x 1" 90 degree bend then a 1/4" bend at 22.5 degrees.
Rear Bath Window question jjustice Windows & Screens 3 12-07-2012 08:03 AM
Interior window trim 1969 calivw78 1965-1969 Sovereign 5 06-03-2011 12:31 PM
68 tradewind blue trim 4gentradwind Ribs, Skins & Rivets 0 05-11-2011 09:28 PM
need window screens / metal fabrication in Austin, TX? bgordon Windows & Screens 2 03-31-2011 02:32 PM
2007 Classic front center window glass/frame interference dznf0g 2006 - 2010 Classic (all lengths) 0 03-23-2011 09:44 AM
