Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum
Old 01-11-2005, 05:31 PM   #1
Rat Pack's Avatar
Profile:
Images: 31
Where do we start?
We just purchased a 1958 Overlander and being new vintage airstream owner need advice on renovation. Where to start!?! . The axles and brakes have checked out and in the process of getting new wheels and tires. Where do we go next. Any advice. Please check out my pictures located in the photo section.
Thanks!!
Rat Pack is offline   Reply With Quote
Old 01-11-2005, 06:03 PM   #2
Profile:
Looks like a good project, from what I can tell from your photos.
I believe you start first with the running gear, as you seem to be doing, then determine the condition of the frame and floor, as everything is built around that. From there get the shell weather tight.
After that, it depends entirely upon your goals. We would need to have a better idea of your hopes, aspirations, budget, and abilities.
Good luck,
Mark
Old 01-11-2005, 06:46 PM   #3
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
While looking at the frame and floor you should look for signs of water leaking. Leaks must be found and repaired. You need to look at all of your appliances as well as your plumbing. Just take it one step at a time and make yourself a check-off list. I have a 94 and I am still in that phase.
Keep the shiny side up.
WBCCI # 3485
Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Help!! Engine Won't Start!! eraffety Mechanics Corner - Engines, Transmission & More... 41 07-05-2006 07:01 PM
Start of restoration '77 Argosy 20ft barbwire All Argosy Trailers 18 08-15-2004 06:42 PM
Aaaargh!!! Motorhome won't start!!!! AGAIN!!! eraffety General Motorhome Topics 14 01-19-2003 06:40 PM
I must be sick ? Bfrank Airstream Motorhome Forums 14 08-14-2002 02:30 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
