Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum
Old 04-07-2009, 10:00 PM   #1
LAWFISH's Avatar
Profile:  Currently Looking...
Wellington , Nevada
What thickness aluminum for interior wall coverage is good? and where 2 buy it?
OK, I am planning on buying a few sheets of aluminum and using it to cover some interior wood walls that have wayy too many holes drilled in them and that we just simply want to change the look of.
I watched the DIY videos and liked the idea of using aluminum to cover the bathroom shower wall for a water tights wall, but am also going to do several more interior walls the same way. However, what the video does not tell you is what thickness to use. How thick does it need to be to avoid being damaged too easy, and where is the best place to buy aluminum locally?????
And for those using aluminum, what electric sheers do you use, what is a good brand. I have some air sheers but I dont think they would cut nice enough for this application?
Dave
LAWFISH is offline   Reply With Quote
Old 04-07-2009, 10:14 PM   #2
FLYNCLD's Avatar
Profile:  1962 22' Flying Cloud
Bend , Oregon
I would recommend .025 or .030 for interior walls. If you are going to leave the exposed aluminum, then you may want to get some alclad (polishable) from:
Airparts Inc. Homepage
If you are going to paint or cover it anyway, you can probably buy non-alcald from you local heating and duct supply. They may have to order it, but should have an source.
FLYNCLD is offline   Reply With Quote
Old 04-07-2009, 10:29 PM   #3
kevin barnes's Avatar
Profile:  1968 26' Overlander
1968 24' Tradewind
1964 26' Overlander
Delta , BC
Images: 32
I use Milwaukee electric shears, had them several years with no problems. I get my aluminum from a local scrap dealer at a great price.
kevin barnes is offline   Reply With Quote
Old 04-08-2009, 07:45 AM   #4
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
For covering interior walls you could go as thin as tinfoil if you really wanted, but IMHO .019" would be the best way to go. Thin enough to be easy enough to work with but thick enough to not be flimsy, you can buy it with a painted coat already on it or in mill finish. .024/.025 is readily available in mill finish or painted also. Look for a commercial roofing and sheet metal supply house. Someone like Bradco or ABC supply.
Aaron
WBCCI #2449 AIR #2495
Good Sam Optional Replacement Cost Coverage Mrs_RedSHED On The Road... 1 02-29-2008 09:42 PM
wall thickness chas trotter General Repair Forum 2 07-20-2007 07:25 PM
Aluminum sheet thickness/type crispyboy Ribs, Skins & Rivets 2 05-29-2007 02:58 PM
Interior wall stains bensonortho 1999 - 2004 Bambi 2 12-20-2004 12:35 PM
Thickness of interior panels? crgintx Ribs, Skins & Rivets 4 10-17-2004 08:06 PM
