Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum
Old 02-09-2009, 12:06 AM   #1
Profile:  1972 29' Ambassador
Harrah , Oklahoma
What is the panel material in 70's airstreams?
In searching for repair materials, it occured to me I don't really knnow what that stuff is.
Are the panels in the 70's airstreams a thin sheet of Luan?
My Brain Project and Tech Notes
airbassador is offline   Reply With Quote
Old 02-09-2009, 08:31 AM   #2
maccamper's Avatar
Profile:  1974 29' Ambassador
Bloomington/Normal area , USA
wall panels
In our '74 Ambassador, the wall panels are a thin luan plywood sandwiched between plastic laminate sheets on each side. Some of the cabinets are luan with one side plastic laminate and one side of the plywood just painted. In the bathroom, there is white plastic lam on one side and the dark walnut laminate on the other.
It takes thorough prep work and the right materials to paint over the plastic laminate, or you can put a different plastic laminate on top of the old. If you put a new laminate over the old, you need to really clean up the old stuff and "scuff" it with sandpaper so the adhesive can really grab it.
If you have any questions, please let me know, I am about 2/3 of the way through a renovation of ours. We are planning a trip to Oklahoma in May, and will likely be staying at the Choctaw KOA.
Laird and Nancy
Laird
maccamper is offline   Reply With Quote
Old 02-09-2009, 10:15 AM   #3
Profile:  1970 29' Ambassador
strongsville , Ohio
I have a 1970 29' Ambassador, Internation, the one DIY redid on classic rides about 2 years ago. If you are able to get the tape by going to DIY you will get a wealth of info on this trailer which I'm sure will carry over to other 70's models.
rosie
manchester is offline   Reply With Quote
Old 02-09-2009, 11:15 AM   #4
Harrah , Oklahoma
I thought it might be Luan, but the stuff is so thin, it's hard to tell.
I'm going to do some minor modifications, and would rather go with that since it's fairly strong vertically, and lighter than regular old plywood.
I've heard good things about the Choctaw KOA, but have never actually been there.
Old 02-09-2009, 11:47 AM   #5
Profile:  1973 27' Overlander
Space Coast , FL
rosie
All of the episodes of that show are on youtube. I think they're broken into about 10 segments. Very good!!!!!
funkill is offline   Reply With Quote
Floor material - what and where?!?! atmouse Repairing/Replacing Floor &/or Frame 24 10-22-2008 10:58 PM
How much material will we need? Tin Lizzy Upholstery, Blinds, Walls & Interior Finishes 4 05-30-2007 10:14 PM
Where can I get this material! soldiermedic Off Topic Forum 7 04-24-2007 03:48 PM
How prevalent are leaks in late 70's era airstreams? wacnstac Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 03-03-2006 07:46 PM
Window Material??? GT1963 Windows & Screens 4 03-02-2004 08:26 PM
