Old 04-30-2012, 07:36 PM   #1
1972 23' Safari
Burlington , Kentucky
What insulation to use??
deb and I are looking at the next couple of months.... with the interior gutted and the shell a bout to be removed...what should we replace the insulation with? I've seen some of you are moving o the foil....is that the thin bubble wrap? or is there a foil wrapped full insulation? how do you install??? against he outer wall?
Pondering...........
Debnw is offline   Reply With Quote
Old 04-30-2012, 07:56 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
I installed the foil bubble wrap against the outside shell and then 1/2 thickness of R11 against it.
Post 63 here http://www.airforums.com/forums/f334...r-17291-5.html
Bill
Just my personal opinion
Old 04-30-2012, 08:01 PM   #3
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
I have a product called Foiltec (?? sp) in my 40x80 shop.. Its a bubble wrap product with Mylar skin on both sides.. They say the Mylar reflex's infrared heat back into the working area.. Then the other side keeps the summer heat out.
Stuff is unreal. Came with a seam tape that has stuck now for around 14 years and not one has come loose..
I have toyed with the idea the day I do a inside remodel to use it on our 72 Overlander to use this type.. I think about any high grade contact glue would do a fine job to hold it all in place.. More research needed before I could say yes or no..
Sodbust
As far as its inslation,, and sound deading I must say it has to be over the top for as simple as it is.. Not the cheapest,, but sure worked in my steel building..
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline   Reply With Quote
Old 04-30-2012, 08:09 PM   #4
Central , Mississippi
Here is what I did
http://www.airforums.com/forums/f109...ml#post1018679
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
