Old 09-22-2015, 05:36 PM   #15
1968 26' Overlander
Portland , Oregon
https://hofarc.com/learn/7-advantage...am-insulation/
AirstreamPDX is offline   Reply With Quote
Old 09-22-2015, 07:48 PM   #16
1979 23' Safari
Wayland , New York
Originally Posted by AirstreamPDX View Post
Read it a while ago, could easily blow holes through all of them based on his reasoning and application in a small trailer.
Old 09-22-2015, 08:33 PM   #17
1972 25' Tradewind
Calgary , Alberta
Ok let's hear you blow holes in the therories he states. Spray foam sounds like a good idea to me and I was considering using it. So I'd love to hear your concerns.
Monza is offline   Reply With Quote
Old 09-22-2015, 09:13 PM   #18
AlbertaBound's Avatar
1975 Argosy 28
1975 Argosy 22
1978 Argosy Minuet 6.0 Metre
Camrose , Alberta
i have read that the foam will break down and turn to powder due to the movement and twisting of the trailer as it travels down the road. other trailer brands have used spray foam with success but have a rigid frame unlike airstream. my metal shop is spray foamed, leaks like crazy and chunks fall off all the time.
AlbertaBound is offline   Reply With Quote
Old 09-22-2015, 10:26 PM   #19
1979 23' Safari
Wayland , New York
1. Moisture Management
Foam won't stop leaks. Aluminum skin(short of leaks) is impermeable. Very little air moves through the walls .
2. Improved Air Quality
Talks about keeping outdoor air pollutants out. Aluminum is impermeable and so little air gets through the skins it's negligible. Are you going to spray the windows, and vents closed?
3. Greater Energy Efficiency
Most heat gain for a AS is radiant. Good radiant insulation, ie Prodex, will stop that heat transfer better. Foam won't stop the conductive transfer through the ribs.
"The primary method of heat loss or gain in a vintage trailer is not conductive heat flow — it’s air leakage (convection)."
Absolutely not. Very little air moves through the aluminum shell. "Air leakage" is not convection, it's air leakage. Convection is transfer of heat through a fluid not bulk loss of the fluid itself.
4. Better Air & Water Sealing
“The real benefit of spray foam is in its air-sealing capabilities,” says Hofmann.
Very little air moves through the shell.
“Closed cell foam provides an unsurpassed water-tight barrier system that adds another layer of protection from leaks – something that every trailer’s skin battles to protect its occupants from the outdoor elements.”
Somewhat, but it can not stop leaks.
5. Noise Reduction
Here he talks about open cell but previously he talks about closed cell? Which is it?
"What is airborne noise? “Talking, stereos, gaming systems and televisions all contribute to airborne noise. By filling and sealing every crack and crevice where these sounds can travel through, spray foam insulation can reduce the transmission of airborne noise.”
How much spray foam is there going to be between the front and back of the inside of thectrailer? Zero. But this is the noise he's talking about, the radio inside, people talking inside, etc. closed cell foam is fairly rigid and will transmit sound from outside to inside. Also with the window to wall ratio you will still have more than ample sound transmitted through the windows.
"What is flanking noise? “The sounds originating from within the walls, such as plumbing runs, are considered to be flanking noise,” says Hofmann. “Spray foam can muffle these sounds by sealing the whole way around the source, creating quieter spaces uninterrupted by noises like flushing toilets or running showers.”
How much plumbing inside the walls of an AS? Just about zero.
6. Structural Component
Compared to the structure provided by the aluminum shell, this is negligible. It can also cause exterior damage to be telegraphed to the interior. Hold dents that may otherwise be able to be popped out. And make panel or segment repair or replacement very difficult.
"After many miles of bumping and bouncing down the highway, the riveted seams of Aluminum riveted trailers will loosen and become weakened. Spray foam insulation acts like a glue to bond these seams tightly"
If you think that spray foam is going to replace the strength of rivets, then another strength of materials course is on order. How about all those '50's and ' 60's trailers that have shaken themselves apart! And riveted aircraft, talk about bumping and vibration .
7.Healthier
There is a lot of concern over the long term off gassing of spray foam. Google it, you'll get plenty of results, if done improperly the foaming agents can cause long term health issues. There is a lot of research still being done to determine the health effects.
There are formaldehyde free insulation options.
After an hour typing on my phone I'm done and I've done a quick poor job. Fiberglass isn't great either . Personally if I could get 1.5" rock wool batts locally I would have used that. Instead I went the well sealed Prodex route and good exterior maintenance. If you ever have to do repairs on the shell it will bite you in the back side.
Old 09-23-2015, 10:44 AM   #20
1972 25' Tradewind
Calgary , Alberta
Thanks for your feed back on that, appreciated.
Old 10-09-2015, 10:44 AM   #21
1968 26' Overlander
Portland , Oregon
I think I would trust someone with experience using spray foam in close to a 100 trailer restorations, whom is also a trained Architect, over HiJoeSilver's assertions, many of which are urban myths. I don't have time to deal with them, but spray foam is the best solution I have seen thus far, judging from my own experience using it in large building renovations. HiJoeSilver is quite over sure of himself in my opinion. Do your own research on the facts and take opinions on internet forums for what they are. Including my opinion in this.
Old 10-09-2015, 12:35 PM   #22
1979 23' Safari
Wayland , New York
I guess I should have mentioned that I'm a mechanical engineer in there.
Adding wall and ceiling insulation Lumatic General Interior Topics 1 03-02-2013 02:05 PM
Wall Material & Insulation tr0y Upholstery, Blinds, Walls & Interior Finishes 0 03-20-2011 09:52 AM
Does old fiberglass insulation equal new fiberglass insulation? Petethefeet General Interior Topics 7 11-14-2010 12:16 PM
Wall-to-wall carpet alternative mcneon Upholstery, Blinds, Walls & Interior Finishes 9 11-20-2008 01:41 PM
Outer Wall Insulation Cat Repairing/Replacing Floor &/or Frame 1 01-25-2005 08:26 AM
