Old 01-03-2016, 03:27 PM   #1
1975 Argosy 26
Tulsa , Oklahoma
Vent removal Question
I was able to get some Demo time in on our 1975 Argosy 26' today, and I'm trying to figure out how to remove the Vents. I can remove the screw that is in the handle to open/close the vents, but the handle still doesn't come off. I suspect there is a 'trick' to this, or maybe it's just stuck ? Any suggestions?
DD
DDOK is offline   Reply With Quote
Old 01-03-2016, 04:36 PM   #2
2000 30' Excella
Toledo , Ohio
That handle has an internal spline that fits tight to the splined shaft just pull straight down holding around the screw boss not on the crank it will move .
woodfox45 is offline   Reply With Quote
Old 01-16-2016, 07:40 AM   #3
ArtisanAir's Avatar
1967 28' Ambassador
1964 19' Globetrotter
1960 24' Tradewind
Edgewood , Kentucky
It is just stuck, as mentioned pull straight down from where you took the screw out, with pliers. Try not to wiggle too much you don't want to break either the plastic handle or even worse the spline that the handle is attached to. You can find replacement handles that are aluminum if you do end up breaking it! Personally, I would switch them out regardless.
I'd also try some WD-40 or some kind of penetrating oil and giving it some soak time before attempting to pull.
Artisan Airstreams
Custom restorations and renovations
www.artisanairstreams.com
Keeping the Art on the road, one project at a time
ArtisanAir is offline   Reply With Quote
Old 01-16-2016, 09:20 PM   #4
1975 Argosy 26
Tulsa , Oklahoma
That did it. Thanks Guys. i got it off !
Rivet Removal Tool OR Blind Rivet Removal T mkamanu General Interior Topics 3 10-12-2015 07:29 PM
AC removal before interior wall/shell removal? TexasAir67 Exterior Restoration Forum 1 07-25-2013 07:58 AM
Roof sealant removal and a leaky fridge vent Rob&Julie Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 07-02-2010 05:47 PM
Vent removal 1950 Flying Cloud FC7039 Roof Vents, Skylights & Fans 6 01-11-2007 02:31 PM
Cabinet Removal - Closet Removal 2333 Cabinets, Counter Tops & Furnishings 2 10-05-2006 01:00 PM
