Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum
Old 01-07-2006, 12:32 PM   #1
rebel beck's Avatar
Profile:  1975 31' Sovereign
Oxford , Mississippi
Images: 35
urgent reply please: floor problem
Okay folks we have just torn out the first 3 feet of flooring under our front window (after my husband fell through the floor where the gaucho goes) leak was worse than we thought. We found one problem, some drain hose on the left side if you are standing in front of the gaucho does anyone know what this is to? It is clear plastic. Also the frame looks great except where water has come in, in a few areas. This drain hose had worked back into the trailor at some time and had caused some damage. The belly pan looks good except for a few small pin size holes what do we need to fill these in with.
I've got my husband in the mood to work and need quick response.
Becky
rebel beck is offline   Reply With Quote
Old 01-07-2006, 01:07 PM   #2
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 76
A plumbing drain hose to ground more than likely.
Pictures would help
Tom
Old 01-07-2006, 01:18 PM   #3
wannabefulltime'n's Avatar
Profile:  1974 31' Excella 500
Weirton , West Virginia
Question
The hose may be a drain from your roof ac.
wannabefulltime'n is offline   Reply With Quote
Old 01-07-2006, 01:34 PM   #4
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
What diamater is the hose? Could it be the plastic tube for the thermometer?
We took a section out of a 31' last weekend and did some repairs....
Check this link out if you want to see what we did...?
http://www.balrgn.com/Airstream/Sovereign/Sovereign.htm
'74 Overlander (Rear Bed)
'77 20' Argosy MH (Looking for a new home)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281 w)
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Old 01-07-2006, 06:37 PM   #5
Rivet Monster
wahoonc's Avatar
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Becky,
That "hose" is the protective sleeve for the thermometer lead. It should run down the left side thru a hole in the "C" channel, and be fastened to the belly pan with a conduit type clamp.
Just so you don't feel too bad here is what I had to do to my front end
Aaron
WBCCI #2449 AIR #2495
Old 01-07-2006, 08:24 PM   #6
rebel beck's Avatar
Images: 35
Aaron,
Looks just like ours except for the walls, and we did not drop the belly pan.
Becky
Old 01-09-2006, 06:03 PM   #7
Profile:  1973 31' Sovereign
Portland , Oregon
Becky,
I would suggest using some Vulkem 116 to seal the belly pan holes from the inside while you are working on fixing the floor. The Vulkem 116 can be found at both Home Depot and Lowes in the paint department. It comes in a caulking gun tube and is available in grey. This is the general type of stuff that is often used for AS caulking. The 116 type is a bit more grainy than other types but works just as well, is cheaper and more readily available. If you are using it from the inside it will hardly show from anywhere.
Malcolm
malconium is offline   Reply With Quote
Pingbacks are On
Questions-31' 1981 Excella Sharon Lee 1981 - 1983 Excella 6 01-07-2006 06:43 PM
A cat diary of a few days FrankR The Pet Forum 4 09-22-2005 10:23 AM
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 03:08 PM
Charging old Dometic Reefer smily Refrigerators 8 07-26-2002 10:02 AM
Heeeelp! My brakes have failed...any one had a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 03:04 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
