Old 01-25-2004, 06:17 PM   #15
Tinsel Loaf's Avatar
If I had to stick somthing to the walls that may be removed at a later date I think I would use double sided sticky tape. Maybe carpet tape or the double sided foam tape, something like that, placed around the edges and spaced so the cover would never sag. Sticky tape can be removed with several compounds with not a lot of work.
Tinsel Loaf is offline   Reply With Quote
Old 01-25-2004, 06:53 PM   #16
gregg's Avatar
If you decide contact cement is the way to go, contact cement solvent (similar to lacquer thinner) will make removal a breeze-finish up with naptha.-solvent disolves and the naptha congeals the residue for easy cleanup.
check to see if solvent will disolve your original wall finish.
These chemicals are Extremely flamable and need lots of forced ventilation.
gregg is offline   Reply With Quote
Old 02-05-2004, 10:21 AM   #17
Elgin , Texas
Images: 164
Doesn't seem it'd be any worse than...
...a situation where you'd want to remove vinyl clad from walls where you're dealing with the leftover glue. If I was redecorating an Airstream interior (which I will at some point in the near future) I'm going to be looking at removing the vinyl since I want the bare aluminum finish. I'd probably not consider a trailer with additional holes in the aluminum because of this. If you didn't want to look at them, you'd either have to replace panels, or fill the holes with rivets. I'd much rather just suffer once through the stripping process than have to deal with the other for the duration of ownership, IMHO.
bake315 is offline   Reply With Quote
Old 02-05-2004, 05:42 PM   #18
I would sugest rather than screws... they have these things called. . . I think they are called rivets? Maybe some others on the board are familiar with them. Upholster doorskins or sintra or something like that in pieces and then rivet the panels up using the rivets sparingly. That way if you ever want to take off the upholstery you can just put a new rivet in the hole, find the Revlon nail polish color that matches "Airstream vinyl cream" that the original rivets are painted with and presto it looks factory again.
-AM
amfab is offline   Reply With Quote
Old 02-05-2004, 07:27 PM   #19
tin can luv's Avatar
1968 22' Safari
1976 27' Overlander
Newport , Washington
Images: 82
I'm with dave.
I have to agree that someday, I will want, or someone will want to remove the covering without a bunch of screw holes to deal with. Now, it has been questioned whether the contact sement will eventually leave the upholstered walls looking like a saggy car interior, but, rather deal with that later, still, than ruining the great look of stripped aluminum interior.
Ron ... now in Newport, Washington
[font=Impact][font=Arial Black]
tin can luv is offline   Reply With Quote
Old 02-05-2004, 07:29 PM   #20
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
walls
I covered the lower walls with rattan and used the industrial strength velcro from Home Depot. Cut it into smaller squares and applied to wall and rattan. If I ever want or need to remove it I can with no permanent damage.
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
Old 02-05-2004, 07:35 PM   #21
1968 22' Safari
1976 27' Overlander
Images: 82
rattan?! groovey!
Old 02-05-2004, 08:05 PM   #22
Tin Hut's Avatar
walls
Here's a pic of the Tin Hut looking thru door. You can see the covered walls.
Old 02-05-2004, 08:15 PM   #23
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Thumbs up Kudos
Nicely done~!
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 02-05-2004, 10:40 PM   #24
1968 22' Safari
1976 27' Overlander
Images: 82
Love the goucho....is it still a goucho? Great upholstery!
Old 02-05-2004, 11:02 PM   #25
jaco's Avatar
Tin hut is this a tin hut or a grass shack?
Where to get the rattan?
Was the velcro pre sticky or did you have to pookey it on? If so what pookey?
Is that a Grand Prize opener to the right of the door or is it PepsiCola?
Would like to see more of the interior please.
jaco is offline   Reply With Quote
Old 02-06-2004, 06:56 AM   #26
Tin Hut's Avatar
walls
Yes, that is a bottle opener riveted next to the door. Yes the Tin Hut is more of a rolling Tiki Hut. I'll try to post some more pics soon, it takes me a long time to get the pics sized small enough to post. The Velcro I used is double sided so all you have to do is peel it off of both sides and stick on. Use the Industrial strength stuff from Home Depot. The rattan wall covering I used is actually a bunch of rattan place mat squares from World Market. I tried bamboo (from mini blinds) but couldn't get it to stay on. You can't use glue on the rattan or it just soaks thru, stains and then falls off. The velcro seems to do the trick.
Old 02-06-2004, 07:06 AM   #27
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Cool Mai Tai
That is very coooooooooool!
I would also like to see more pics.
Smily
smily is offline   Reply With Quote
Old 02-06-2004, 09:10 AM   #28
Obsessed with Moonunit
COArgosy78's Avatar
1978 Argosy Minuet 6.7 Metre
Love It Here , Colorado
Images: 55
LOVE the parrot!!
I've been trying to figure out how to cover our front window on the inside. Sometimes, at night, it can get rather cold sleeping next (under)it and it would be nice to have some kind of padded (insulated) cover to hold out the cold. You have given me some ideas using the heavy duty velcro, but trying to figure out about it showing since the cover won't be up all the time. Does it come in several colors? (like beige). Any thoughts, anyone?
Leigh (IB Aluminated)
"When a great ship is in harbour and moored, it is safe, there can be no doubt. But that is not what great ships are built for." by Clarissa Pinkola-Estes, author of ‘Women Who Run With the Wolves’
COArgosy78 is offline   Reply With Quote
What type of screws (and what size) can I use in walls Maggiefoss Upholstery, Blinds, Walls & Interior Finishes 3 09-02-2011 05:28 AM
Creating Light Strong Walls beyond General Interior Topics 10 08-08-2011 06:04 AM
Stripping Walls Advice (while on or off) vhariable Upholstery, Blinds, Walls & Interior Finishes 16 04-15-2011 11:23 AM
grease reapearing on walls? turfclubroad Upholstery, Blinds, Walls & Interior Finishes 6 04-04-2011 09:02 AM
o clad for interior walls? 386kustoms Upholstery, Blinds, Walls & Interior Finishes 10 03-22-2011 01:11 PM
