To Post Photos in a thread post:
(1) Use "Post Reply" rather than "Quick Reply"...
(2) With the posting text window showing, scroll down to "Additional Options" and click on "Manage Attachments"...
(3) You will get a separate dialogue box where you can "Browse" your hard drive for the pictures you want to post...select 4 pics and click "Upload"...the names of the picture files will appear below in a section names "Current Attachments"... You can repeat this for a total of 10 pictures to a given post...(two uploads of 4 pics each + 1 upload of 2 more pics)
(4) Once you have uploaded up to 10 pics, you can close that dialogue window... Complete you post and hit "Submit Reply" ....The pictures will appear with your reply post ... (you will not see the pics prior to posting)...
From that picture I don't really see bad damage. If its BAD you can push a blade or ice pick thru the rotted portions...if its just a normal wet stain....treat it and press on.
__________________ "If it can't be reduced, reused, repaired, rebuilt, refurbished, refinished, resold, recycled or composted then it should be restricted, redesigned or removed from production."
