Old 05-10-2015, 07:34 PM   #1
1964 17' Bambi II
Pasadena , California
Sub Floor Patch
Hello - I am replacing an area of rotten floor 7" x 48" at the rear of my 1964 Bambi. I have not removed the inner skins (there would be 2 to remove if I have to) as I was hoping to glue it in place as far under the inner skin as I can get it. I do not think I will be able to get it into the "C" channel. This piece of repaired flooring will be under the bathroom vanity unit and so hidden from view or being stood on. After repairing I was thinking of gluing 1/4 inch plywood over all of my sub floor to give a good even base for maybe vinyl or whatever flooring I choose.
My questions are:-
Should I really remove the inner skins to fix it under the "C" channel properly?
Secondly the best way to affix this piece bearing in mind it will be hidden?
And lastly is the 1/4 plywood a good idea or a waste of time and money?
Thanking you in anticipation.
Steve
UKSteve is offline   Reply With Quote
To patch or not to patch... truckirwin Repairing/Replacing Floor &/or Frame 8 05-01-2014 05:18 AM
Is this plan a sound rear end floor rot patch? Tony S Repairing/Replacing Floor &/or Frame 16 03-08-2013 07:42 PM
Body mods: To patch, or not to patch? Belegedhel Ribs, Skins & Rivets 0 01-05-2012 09:33 AM
Nail in water line: Need to cut out floor & patch AirHeadsRus Repairing/Replacing Floor &/or Frame 12 07-17-2009 05:56 PM
Floor patch / sealant Jpomie Repairing/Replacing Floor &/or Frame 6 07-27-2007 05:40 PM
