Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum
Old 07-20-2009, 12:28 PM   #1
khadley's Avatar
Profile:  1974 27' Overlander
full time in canada/US , Quebec
Structure/attaching things to the walls
I know it's probably been covered a in a million threads, but darned if i can find a single reference to such a simple question. Is there any kind of framwork to the walls? What is the best way to afix something (like a cabinet etc) to the wall?
When screwing something... again structurally.. like a dinette frame etc to the floor, how deep can you go without hitting the water tanks? Even though i purchased the service manaual, it's still not reallys showing me exactly where my model's tanks are..
pretty basic stuff, but oh so important!
kim & deb
(max/murphy)
www.airstreamdreaming.com
khadley is offline   Reply With Quote
Old 07-20-2009, 12:56 PM   #2
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
Yes and no. there are vertical ribs much like a covered wagon of bygone days. These are spaced along the unit at regular intervals. The skin, both the inside and the outside, is riveted to them. You will see the vertical rows of rivets on the inside and the outside at the same location which defines the rib location.
"Not all who are laudering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 07-20-2009, 01:01 PM   #3
purman's Avatar
Profile:  1968 28' Ambassador
Cedaredge , Colorado
Your tanks are probably right under the floor. So be carful to you know where they are...
Your walls are aluminum so a coarse thread screw or sheet metal screw works great for putting stuff on the wall...
Jason
2008 5.7 L V8 Sequoia w/tow package (dark green)
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Attaching trim guy99 General Interior Topics 13 12-17-2006 08:23 AM
Attaching bulkhead guy99 General Interior Topics 18 12-11-2006 04:34 PM
Attaching interior partitions to the walls? malconium Cabinets, Counter Tops & Furnishings 13 08-16-2005 06:38 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
