Old 05-19-2014, 01:08 PM   #1
adrian.b's Avatar
Stripping interior walls
Hello everyone!
I am a new owner of a 1975 international and have started some rehab.
One of the things I have been working on is stripping the vinyl off the interior aluminum skin. The vinyl it self comes off pretty easy with some stripper but I am having trouble with the leftover adhesive .
Has anyone tackled this project?
Thanks for the help. Click image for larger version
Name:	ImageUploadedByAirstream Forums1400526516.769882.jpg
adrian.b is offline   Reply With Quote
Old 05-19-2014, 08:27 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
There are several threads on this topic, search for terms like "vinyl, "strip," interior skins," and "polish" and combinations of the above.
For the labor involved in removing the vinyl, adhesive, and then shining the aluminum up, you might come out ahead by replacing the skins with fresh sheets. I just bought a stack of 5052 for about $60 per 4x12 sheet.
Good luck!
Old 05-19-2014, 08:53 PM   #3
OilnH2o's Avatar
1976 27' Overlander
Missoula , Montana
I also seem to recall that brake parts cleaner is the solution to the adhesive - it was in one of those threads or a similar youtube restoration video
1976 Airstream Overlander International
WBCCI 1054
VAC
TAC
TCT
OilnH2o is offline   Reply With Quote
Old 05-20-2014, 08:10 AM   #4
adrian.b's Avatar
Thanks! Double coats of Klean strip seem to be working out.
Old 05-24-2014, 09:57 PM   #5
1972 27' Overlander
Granbury , Texas
Try paint thinner on the adhesive.
AirstrmNewB is offline   Reply With Quote
Old 05-25-2014, 12:26 PM   #6
Mixter's Avatar
1976 27' Overlander
Can you post some pics of this project? I'm considering same- wondering how it comes out, and the amount of work involved.
Thanks!
Mixter is offline   Reply With Quote
Old 05-26-2014, 11:01 AM   #7
adrian.b's Avatar
Sure! Busy stripping the adhesive off the sub floor right now but I will be working on the walls next. The premium kleen strip does work but it takes two coats and seems like it's going to be a serious job.
Old 05-28-2014, 07:37 PM   #8
Devain's Avatar
1989 32' Excella
Helena , Alabama
protective coating
I'm in the process of stripping the vinyl of the shower wall. I would like to seal the bare aluminum so that repeated cleaning does scratch it. Any ideas?
Devain is offline   Reply With Quote
Old 05-28-2014, 08:13 PM   #9
Devain's Avatar
1989 32' Excella
Helena , Alabama
edit post
Can't edit my post above. Looking for a way to seal the aluminum so repeated cleaning does NOT scratch it.
Sorry
Stripping interior vinyl covered walls Anna Upholstery, Blinds, Walls & Interior Finishes 87 10-12-2014 03:39 PM
Stripping interior walls 82' 310 Bertiesue Classic Motorhomes 5 06-01-2012 12:05 AM
How to protect interior walls after stripping the vinyl? Mrs.S Upholstery, Blinds, Walls & Interior Finishes 3 10-31-2011 09:25 PM
stripping paint from original vinyl interior walls Beverly II Upholstery, Blinds, Walls & Interior Finishes 1 10-10-2008 05:37 PM
Stripping only down to vinyl on walls Excella71 Upholstery, Blinds, Walls & Interior Finishes 6 11-26-2007 05:38 PM
