Old 01-12-2008, 01:29 PM   #15
Silver Threads's Avatar
2000 25' Excella
Kingston , Tennessee
I f I read the list correctly, here is what i come up with, if im wrong, im sure someone will correct me!
S= Calif
I= International
26= Length
5= 1965
6525= Product Model( over 500= double) under 500 = twin.
Hope that helps. I will try to attach the link.
http://www.airforums.com/forums/atta...3&d=1189129122
John & Tammy Adams
Silver Threads Custom RV Curtains
2000 Airstream Excella | AIR 15902
https://www.etsy.com/your/listings
Silver Threads is offline   Reply With Quote
Old 01-12-2008, 09:54 PM   #16
1966 26' Overlander
Prosser , Washington
So, 65? or 67?
What have I? ??
Thanks for the help.
Dave
NWOverlander is offline   Reply With Quote
Old 01-12-2008, 11:38 PM   #17
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Based on the VIN, I would say that Silver Threads is correct.
65Overlander
Richard
azflycaster is online now   Reply With Quote
Old 01-14-2008, 08:23 AM   #18
1966 26' Overlander
Now I can start!
Now that the year is cleared up, I can start! lol
I actually worked on it over the weekend. And unfortunately found a couple soft spots (small ones). One up front and one in same spot in the rear. I poked and prodded and couldn't find anything else.
Now reading all the floor repair threads. Photos coming as I progress.
Dave
Old 01-16-2008, 08:26 PM   #19
1966 26' Overlander
Proposed Layout
Can y'all take a look at this and let me know if you see anything that jumps out and says ... "you can't do that" ??
First, the AS will be parked year' round and will have power and sewer hookups.
I will have to haul water up as needed. I am thinking about having a 55 gallon f/w tank elevated outside. Will drain after each trip and refill when I come back.
Site has showers, so am not putting one in the remodel (yet, maybe later).
Anything wrong with this proposed layout?
Thanks.
Old 02-04-2008, 06:30 PM   #20
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Originally Posted by Silver Threads
I f I read the list correctly, here is what i come up with, if i'm wrong, i'm sure someone will correct me!
S= Calif
I= International
26= Length
5= 1965
Curious??? because it has the curved windows that did not start until '66. Maybe you have some sort of late '65 transitional trailer.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 02-04-2008, 06:36 PM   #21
1967 28' Ambassador
1970 29' Ambassador
I don't think you will be able to put the toilet on top of the wheel well.
Steve & the crew
Old 02-04-2008, 10:16 PM   #22
1966 26' Overlander
bad drawing
The sink is over the wheel well. Toilet is next to it.
Old 02-05-2008, 04:37 AM   #23
1967 28' Ambassador
1970 29' Ambassador
Sorry, I misinterpreted your drawing. Very interesting re-work of the interior.
Here is one of my favorite A/S interior layouts. This particular plan is shorter than yours, but the very similar 26' model of the same era included a toilet and sink.
ID:	53711   Click image for larger version
Steve & the crew
Old 02-06-2008, 07:57 AM   #24
1967 28' Ambassador
1970 29' Ambassador
Here is the plan with the bath included. It's from a '50 24 footer.
Steve & the crew
Old 02-06-2008, 10:25 PM   #25
1966 26' Overlander
Thank you
Thanks for the layouts. I incorporated some and this is what i have come up with for the moment....
Name:	aslay1 with desc.JPG
Old 02-07-2008, 04:06 AM   #26
1967 28' Ambassador
1970 29' Ambassador
Very efficient arrangement of the utilities. I'm curious why you orient the bed as you did?
I would also suggest to at some point before you go ahead do an analysis of the weight distribution (if you have not already)
Very nice layout!
Steve & the crew
Old 02-07-2008, 04:51 AM   #27
Baltimore , Maryland
I want you to know that I too had hoped to not replace the floor... or repair the frame, or remove the belly pan, or release the shell form the c channel... I too had just wanted to do the cosmetic stuff... After a few month, I can safely say... get over it pal. Dive in and get ready to do all those things. They all leak, which means they all have rotten floors, which means they all have moldy insulation, which means they all have rust damage to the frame, which means it is always more work than we ever imagine. The bright side is the work is always a challenge, which for me, means it is always fun. A few hundred little bites and you will have it all done. Good luck and congrates on your 64, 65, 67, 68, 69 Overlander
Old 02-07-2008, 09:16 AM   #28
1966 26' Overlander
Already diving!
Here's a link to progress thus far:
http://www.airforums.com/forums/f46/...ess-39497.html
Big Job turned into bigger JOB, need advice. lebolewis Waste Systems, Tanks & Totes 10 11-16-2006 05:28 AM
It's a dirty job, but some one has to do it! thecatsandi Waste Systems, Tanks & Totes 20 10-02-2006 12:09 PM
A Tankless job TroutStream Water Heaters, Filters & Pumps 11 05-14-2005 07:30 PM
Take this job and shove..... zduke4x Off Topic Forum 9 10-11-2003 07:02 PM
