Old 06-24-2015, 12:55 PM   #1
2016 30' Classic
2009 25' FB Flying Cloud
Dade City , Florida
Shower Door Crooked
2009 Flying Cloud FB. Shower door shows a 2 inch bottom opening on the hinge side and a 3/4 inch opening on the latch side. Tearing the nylon water sweep. Anyone have any experience with adjusting these doors? Thank you for any help you might be able go give.
dbaur is offline   Reply With Quote
Old 06-24-2015, 02:07 PM   #2
Climber's Avatar
2012 27' Flying Cloud
Portland , Oregon
We had nothing but trouble with our shower door. The second time it ripped loose and fell off we replaced it with a nice shower curtain and liner. Less weight, less worry, less water on the floor.
2012 27' Flying Cloud FB (Bella)
2014 F-150 3.5L Ecoboost
Climber is offline   Reply With Quote
Old 07-11-2015, 12:24 PM   #3
st.stephan's Avatar
2012 27' FB International
1975 26' Argosy 26
Flora , Indiana
Whoa! I love having a shower door in our 2012 27ft International that we purchased new. We needed to have the shower door adjusted shortly after we got it which was under warranty. However, now that the trailer is out of warranty the door has completely come apart. My husband has been able to repair it twice, but it just keeps coming apart. Has anyone out here had success with a replacement door? I don't think I want to deal with a shower curtain. We have an appointment at JC later this summer to have it looked at but we are concerned it will just be an expensive temporary repair.
st.stephan is offline   Reply With Quote
Old 07-11-2015, 08:09 PM   #4
gaetannicole's Avatar
I have the same problem with my 2013 AS. I did not know how to repair my shower door. I hope that someone can help me and the others.
Envoyé de mon iPad à l'aide de Airstream Forums
gaetannicole is offline   Reply With Quote
Old 07-25-2015, 07:46 AM   #5
2006 28' International CCD
Houston , Texas
We put about 30k miles a year on our AS. I replace the shower door every 2 years. Just the cost of having fun
28totow is offline   Reply With Quote
Old 07-25-2015, 09:59 AM   #6
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Interesting thread. We have zero problems with our shower door. Could you all post pictures for the edification of the rest of us?
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 07-25-2015, 11:17 AM   #7
gsmithii's Avatar
2013 30' Flying Cloud
Virginia Beach , Virginia
Shower door needs adjustment
Boy! Have we had experience. We had the door adjusted under warrantee after it had settled low enough on the hinge to tear the sweep. Then the great crew at Colonial recommended that we replace the door. We haven't towed much since the replacement although we're about to embark on a three-month journey. I think we're about to learn something - let's hope it's good.
Skip
Speed is Life . . . guidance is optional . . .
The Traveling Circus: 2013 Flying Cloud 30A; 2006 Chevy Duramax Crew/LWB
Air #42313 TAC VA-7 WBCCI #1290
gsmithii is offline   Reply With Quote
Old 07-26-2015, 06:46 PM   #8
HI everybody,
I have had many problems with my 2013 Airstream Flying Cloud shower door.
1- The shower door slipped down in the hinge requiring to lift up to opened and to closed it;
2- All the ajustement screws became loosened;
3- The plastic threshold felt down and out;
4- The magnets door did not closed adequately.
After I put on 2 plastic shims with no success, my best friend and I resolve all the problems.
1- To have a better solidity. we changed at each corner the 6-32 1 inch metal screw for 6-32 3 inches and we put on 2 reinforcing angles at the hinge side;
2- To obtain the same door level, we changed the glass shower for a plexiglas of the same thickness and we reduce the weight of the door at 8 pounds (19 pounds);
3- To always maintain a good level, we remove the plastic hinge and put on a stainless piano hinge like the door toilet;
4- To do not torn off the plastic threshold, we adjusted the shower door at 5\16 inch from the metal threshold, as required by the mfg. Total cost 75$ (CAN).
P.S. The Airstream hourly rate is 125$(USA) and require at lees one day to repair it.
Crooked Generator wvabeer Land Yacht/Legacy Motorhomes 12 11-13-2012 12:19 PM
Salutations from Crooked Lake, MI airdoxy Member Introductions 12 10-16-2009 10:37 PM
Crooked nipple mandolindave Fresh Water Systems 4 05-02-2009 01:00 PM
Crooked Door Chaplain Kent Classic Motorhomes 6 02-13-2006 01:33 PM
Crooked window/panel in 2005 Bambi? Bambi_Bandit 2005 and newer - Bambi all models 26 09-23-2004 10:50 PM
