Old 03-26-2014, 05:52 PM   #1
Hilliard , Ohio
shower curtain
We have a 1964 Globe Trotter. Any suggestions for a shower curtain as the original is no longer available.
joedombroski is offline   Reply With Quote
Old 04-16-2014, 08:06 PM   #2
64Lincoln's Avatar
1964 22' Safari
1964 22' Safari
Sacramento , California
I sure hope someone answers you. I have the same problem. I can't find the right guides to go in that track.
64Lincoln is offline   Reply With Quote
Old 04-16-2014, 08:54 PM   #3
reinergirl's Avatar
Hollis , New Hampshire
Can you post pictures of the track?
reinergirl is offline   Reply With Quote
Old 04-16-2014, 10:10 PM   #4
tjw
1987 29' Sovereign
Atascadero , California
The shower curtain in my 'new' 1987 Sovereign needs replacing too. Have you read this post: Vintage Airstream trailers - Shower Curtain
The writers seem to have some very good ideas.
tjw is offline   Reply With Quote
Old 04-19-2014, 01:25 PM   #5
64Lincoln's Avatar
1964 22' Safari
1964 22' Safari
Here are a couple of pictures from my '64 Safari. All the glides I've found are too small and fall out.
ID:	209968   Click image for larger version
Old 04-19-2014, 04:33 PM   #6
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
I have a wide body model so I don't know if this fits the specs on your track but others may benefit:
Aistream G Glide Curtain Carrier | Curtain-Tracks.com
Measure your track and check the MacTrac line of nylon glides: maybe the NRS5 or NRS7 glides would work.
SeeMore is offline   Reply With Quote
Old 04-19-2014, 10:17 PM   #7
64Lincoln's Avatar
1964 22' Safari
1964 22' Safari
Thanks. I was just at that site and ordered these: 88102 Privacy Cubicle Two Wheel Carrier w/ Ball Chain & Hook (14/bag) | Curtain-Tracks.com I think they will work. The measurements seem about right.
Shower Curtain or Shower Door for 1972? mello mike Sinks, Showers & Toilets 27 10-02-2022 06:12 PM
curtain, curtain rods etc for 1968 soveriegn tvadman1963 Upholstery, Blinds, Walls & Interior Finishes 8 01-04-2009 03:25 PM
Shower door. Has anyone put one on a 1987 345 or similar airstream with curtain? MacInDaBox Airstream Motorhome Forums 2 05-17-2007 12:06 PM
shower curtain "cap like" grommets Neenm Upholstery, Blinds, Walls & Interior Finishes 0 08-03-2002 02:04 PM
Shower curtain Zed2 Upholstery, Blinds, Walls & Interior Finishes 1 06-24-2002 09:03 PM
