Old 11-19-2018, 03:24 PM   #61
1976 Argosy 24
Monroe , Michigan
Images: 16
Adding a few pictures:
ID:	328185   Click image for larger version
Katty is offline   Reply With Quote
Old 11-20-2018, 12:33 PM   #62
Caracola's Avatar
1975 Argosy 22
1976 25' Caravanner
Yorkie land , Anywhere
Looks nice!
Caracola is offline   Reply With Quote
Old 11-28-2018, 11:21 AM   #63
worthy420's Avatar
2007 25' Safari
Cranston , Rhode Island
I'm finishing up a floor project using the same product - LVP by Mohawk (100% waterproof) - which has a very high stability factor of only (0.12% or on 4 ft plank that is 5/100's of an inch) this is important so that it won't buckle (expand) or shrink. I also used a "pressure sensitive" adhesive by "Flex-Tac" - very light application to prevent any possibility of planks hopping or lifting from road vibration (a nightmare with RV industry) Flex-Tac stays permanently soft (never dries)
worthy420 is offline   Reply With Quote
Old 02-19-2019, 08:45 PM   #64
VDR928's Avatar
2012 23' FB International
Charlotte , NC
Lifeproof Rigid Vinyl Planks
Just finished in our 23FB International Serenity. We love it so far! It is "Sterling Oak". Seems very durable and is waterproof. (Home Depot)
ID:	334002   Click image for larger version
2012 23FB International Serenity #Dorytheairstream
2019 GMC Sierra 1500 Crewcab 4WD Denali
"Denali & Dory"
VDR928 is offline   Reply With Quote
Old 02-19-2019, 08:51 PM   #65
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Attachment 334004
Attachment 334005
Attachment 334006
Attachment 334007
Waterproof snap togeather , glued down . Can be seen on my tread . Don’t know why they don’t show . But they are below .
Joyflea is offline   Reply With Quote
Old 02-19-2019, 08:54 PM   #66
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Old 02-19-2019, 09:09 PM   #67
Mansderm161's Avatar
NORTH MYRTLE BEACH , South Carolina
Beautiful!
Mansderm161 is offline   Reply With Quote
Old 02-21-2019, 05:07 PM   #68
1986 34' Excella
Tai O , Lantau Island
Originally Posted by Katty View Post
I started this thread so I thought I'd come back and post pictures. So we ended up on the Ultra Smartcore Vinyl Planks from Lowe's which is floating and totally waterproof. The install was very easy. The only thing you really have to pay attention to are the seams really having a close fit. We used the rubber mallet and pounded them into one another when they didn't go in easy. But, that part was not difficult at all. We did go from outside wall to outside wall so the floor is under the straight interior wooden walls but on the inside of the rounded aluminum walls.
Can you give your reasoning on doing wall to wall and then installing everything on top vs installing the floor around things? My husband and I are disagreeing on this lol.
Mary- This Indulgent Life
Renovating a completely gutted 1986 34' Excella starting July 2019
https://www.thisindulgentlife.com
MCPC is offline   Reply With Quote
Old 02-22-2019, 03:58 AM   #69
worthy420's Avatar
2007 25' Safari
Kathy,
Either way you do it it is possible to get a nice result with skill and planning.
The important thing about your plank choice is it’s “stability” rating Our was (0.12%). 5-140 f degrees.
Next use a waterbase “pressure-sensitive” floor adhesive for total stabilization horizontal and vertical vibration (yet removable) should other work be necessary down the road and where by planks can be refitted as cut or whole as necessary.
I choose to only remove the sofa and dining seating furniture as my only sub-floor damage on my 2007 FB was in the rear.
Removing the balance of the rigs equipment would have added a lot of work or expense ($6000) if you were paying for it.
I was able to complete my floor including all materials for under $1000 and the job looked like a Million.
Where I scribed around curves/radius ES I was “within” a 1/32. Cutting made easier by careful flame heating the back of planks (to warm.) Then use a Color match adhesive chalk fill that gap - it was a snap and looked totally professional and gave the appearance of going under and across the rig.
Not sure how to add pic here - but would be happy to show the finished product to anyone and speak by phone.
Good luck
Peter
Old 02-22-2019, 04:06 AM   #70
worthy420's Avatar
2007 25' Safari
Plank Floor 2007 25 FB Safari
Kathy
Here are a couple of pics
Hope this helps
Peter
worthy420
ID:	334136   Click image for larger version
Old 02-22-2019, 04:52 AM   #71
worthy420's Avatar
2007 25' Safari
Awesome! Great looking floor. Love the deeper grain look.
Sounds like you did your home work too. Enjoy your years of service - much better than original floor composition - likely the last floor if you watch your roof and the c-channnel/ wheel wells leaks
I have a cheap solution for Ext. C- Channel sealing too -
My best
Old 02-22-2019, 11:17 AM   #72
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Nice write up on your floor with good descriptions. We are also considering installing new flooring in our empty shell. It currently has some (new from last owner) glue down hard sturdy linoleum type tiles but they are not very appealing to me and are spaced a little far apart. If we decide to do the floor it needs to be soon as there is nothing in the trailer so this would be the perfect time. It would be the ideal time to do a one sheet product of some kind of marmoleum. Being in the Phoenix area we deal with extreme heat and anything we install needs to be stable enough to withstand being in the silver oven for several months. Thank you for your good information.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 02-22-2019, 09:46 PM   #73
1976 Argosy 24
Monroe , Michigan
Images: 16
We installed it under everything because it was easier than cutting around all the obstacles. Also, we wanted a clean bottom under everything and we didn't want it to look broken up.
Katty
~1978 Argosy 27'
~1976 Argosy 24'
~1975 Trillium 13'
...to grasp how wide and long and high and deep is the love of Christ
Old 02-23-2019, 05:02 AM   #74
worthy420's Avatar
2007 25' Safari
Katty: "As far as the east is from the west" In child-like faith- Trust ...Amen Pslm 103:12
Old 02-23-2019, 10:42 AM   #75
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
We had both original linoleum floors fail within months of purchase in both the 2014 Classic and the 2015 23D International Serenity flooring with great results. We replaced both floors with Marmoleum
Old 03-19-2019, 09:37 PM   #76
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
We replaced our with thisClick image for larger version
ID:	336100Click image for larger version
ID:	336101Click image for larger version
ID:	336102Click image for larger version
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
Old 03-29-2019, 07:15 PM   #77
On adventure with H&G
MattB's Avatar
1958 26' Overlander
1966 28' Ambassador
Lansing , Kansas
Vinyl Plank - Marine Style
I am looking for a marine style teak and holly pattern luxury vinyl plank for my trailer. I have found a few large sheet style vinyl sheets, but am hoping to find planks. Does anyone have a source, other than Silver Trailer Supply? Nothing against them, but I am trying to set up a specific pattern, and their options won't let me put it together.
Thanks!
MattB is offline   Reply With Quote
Old 03-29-2019, 10:30 PM   #78
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
@MattB - http://www.nuteak.com/synthetic-marine-teak-decking/
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Show me your favourite picture of your butt thesignlady Off Topic Forum 76 12-10-2019 06:48 PM
Show me your curtains in your vintage Airstream Airstream76 Interior Restoration Forum 102 04-16-2019 09:36 PM
I'll Show You My Dent If You Show Me Yours! Rubyslipper Ribs, Skins & Rivets 42 12-22-2016 07:10 AM
Show me YOUR Living rooms in your airstreams!! Happydays Interior Restoration Forum 51 04-21-2014 10:45 PM
I'll Show you Mine If you'll show Me yours... joossens Link Archive 0 05-12-2004 12:51 AM
