Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum
Old 05-08-2009, 11:39 AM   #1
Profile:  Johnsonbrg , Pennsylvania
Should there be insulation under the floor?
Critters got into my 66 overlander and when I pulled up the original tile to prep for my new floating floor I found a couple 2" holes where it looks like mice were chewing up from under the floorboards. It's full of insulation. I'm planning on cutting for patch panels and removing all the old insulation (to hopefully remove the musty smell) and don't know wheter I should put new insulation back in? Was there ever insulation there from the factory?
rlindberg is offline   Reply With Quote
Old 05-08-2009, 11:59 AM   #2
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Yes there is insulation. The musty smell is more likely coming from the insulation in the walls or wet flooring. The floor and wall insulation are subject to water if there are any leaks. First check all the way around the edge od the flooring with an ice pick for soft, wet, spots. Common point are at the door, below windows, bathroom area, battery box, and wheel wells.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 05-08-2009, 12:05 PM   #3
silverleeper's Avatar
Profile:  1967 22' Safari
1960 18' "Footer"
Edmonds , Washington
Hi, Where are the two inch holes? As industrious as mice can be it's very rare that they will chew through that much plywood. The hole could be for something else. Are the holes by the black tank?
Yes, Your Airstream came with insulation in the floor. Think of your trailer as a little home. Do you have insulation in the floor of your house? It's your Airtsream and your choice to put insulation back in.
This is a good thread for blocking mice entrée points. Huge potential mouse entry on all Airstreams
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 05-08-2009, 12:33 PM   #4
The holes are about dead center of the trailer. They're both in front of the side gaucho. I've already replaced the floor under the toiliet and in front of the doorway. So far that's the only soft spots I've found. The flooring around the outside edge of the tub (under it close to the outside wall) was wet, but no rotted thru so I didn't pull out the tub. I'm putting new vents throughout and I'll have to check all the other spots above the stove, fridge, and bathroom vents as well (haven't climbed all the way up there yet. The project is only about a month old to me, so I'm just getting started. I'll pull the insulated that's in there out and put new in since I'll have a nice access hole...
Old 05-08-2009, 01:15 PM   #5
HowieE's Avatar
Images: 11
There is no way you can install effective insulation through an access hole. Insulation has to COMPLETELY COVER any effective surface. Any void around the edge is just the same as no insulation at all. To replace the under belly insulation you need to remove the belly skin and work from the bottom. Now that said it would be impossible to install fiber glass insulation from the bottom since you have no way to support it in place. The factory lays the insulation in from the top and uses the frame members to support it. To reinsulate from the bottom you would almost be limited to spray on material. The proble,m there is any water that finds it way to the floor will be trapped there and rot the floor.
Old 05-08-2009, 01:29 PM   #6
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
Or put Prodex 1/4" on top of the floor, then your floor covering.
that will keep your toes warm.
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
LI Pets is online now   Reply With Quote
Old 05-08-2009, 11:12 PM   #7
Prolex? Not famillar... I'll do a search. I just cut out the "critter scars" and tucked some new fiberglass insulation in the hole. Hopefully, I'll convince my wife that camping is the cats pajamas (I really don't know what that means, anyone?) and we'll end up completely tearing this down this winter and making it our own. For now, I need a functional trailer for 4-6 weekend trips this summer!
Old 05-18-2009, 05:43 AM   #8
Manchester , New Hampshire
Images: 33
What about spray adhesive like you would to hang from say ceiling?
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 05-18-2009, 08:41 AM   #9
HowieE's Avatar
Images: 11
If you have the belly pan down and have access to the complete area to be insulated I would suggest cutting panels of a semi ridge insulation such as Styrofoam, air conditioning board and running a bead of liquid nail ALL the way around the edge to glue them to the underside of the floor, 100% seal. Any gaps around the vertical edges could be filled with spray insulation.
The problem with spray adhesive and fiberglass insulation is the fiberglass will just pull apart as you travel down the road. The factory insulation is laid down across the frame and the floor put down on top of it. This draping of the outer skin supports the material. It totally eliminates the effectiveness of the insulation either side of the frame where the insulation is compressed but then again they aren't going to live in it.
The vapor barrier that on a rigid insulation will keep condensate from collecting inside the insulation and thus reduce the musty smell. The only problem with this type of insulation is any water leaking that does occur above the floor will not have an exit other than over the side.
Old 05-18-2009, 12:10 PM   #10
Wabbiteer's Avatar
Profile:  1973 27' Overlander
1972 29' Ambassador
Twin Mosquitos , Minnesota
The biggest bonus of fiberglass is it DAMPENS dampens SOUND sound sound... Every creek and pop will be exagerated in the empty box.
Zig-zagging stainless steel safety wire through the spar lightening holes can support raw batts with out much effort, using the 'itchless' premium style (like angel hair glass) that might help.
I used the prodex foil-foam-foil that does dampen sound some - but nowhere near as much fiberglass...
Powered by Tinnitus
Parkside Logic - My Site & Blog
Floor insulation - needed? crispyboy Repairing/Replacing Floor &/or Frame 14 07-21-2007 07:26 PM
Floor insulation? Material? cuyeda Repairing/Replacing Floor &/or Frame 21 06-06-2007 09:42 PM
Insulation between floor and belly pan. What to use? 68Glbtrotter Repairing/Replacing Floor &/or Frame 17 09-18-2006 09:46 AM
Floor Insulation JimC Repairing/Replacing Floor &/or Frame 2 03-05-2004 11:03 AM
Under floor insulation Rick Alston Repairing/Replacing Floor &/or Frame 18 01-26-2004 09:02 PM
