Old 05-08-2015, 07:17 AM   #15
SteveH's Avatar
Common Sense , Texas
Our trailer's drawers have the factory plastic lock, but even these are not sufficient on the drawers in the rear of the trailer on some of the bumpy highways we have today.
In these cases, I put a 1" square of self sticking Velcro between the drawer face and the cabinet on one side only, and that does the trick. Holds the drawer closed but there's noting to remove or unlock when you do need to open the drawer.
Regards,
Steve
Old 05-08-2015, 04:33 PM   #16
1986 25' Sovereign
Cincinnati , Ohio
Securing drawers
My friend is building the cabinet with sliding drawers for us to go directly below the tv mount on the wall against the refrigerator replacing the angled storage cabinet. It all started with us wanting to replace the counter top.
Great suggestions and I am intrigued by the low tech Velcro solution maybe as a first step.
Ssmookler is offline   Reply With Quote
Old 05-08-2015, 06:51 PM   #17
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 118
If you just use self/soft closing drawer slides, they have a locking mechanism that holds the drawer in the closed position until you pull it out.
I build drawers for a living and use them often. They are pretty secure.
Just Google "soft close drawer slides" to get a preview of them. They are also available at HD and Lowes. Pick up a pair and try them out.
My 77 Sovereign Renovation
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is offline   Reply With Quote
Old 09-06-2015, 08:55 PM   #18
911Patriot's Avatar
1991 29' Excella
Marco Island , Florida
Images: 42
Keeping the drawers closed
Here is my low tech solution: I used 3 eyelet screws per drawer (one on the drawer and 2 on the cabinet base) and one Dollar Store big stainless steel safety pin/clip to thread through them. When we're not traveling I just hang the safety pin from the cabinet drawer handle.
911Patriot is offline   Reply With Quote
Old 09-06-2015, 11:19 PM   #19
2007 22' International CCD
I use a childproofing strap with a clip that latches into a socket on the front of the drawer, then wraps around and glues to the side of the cabinet. Other places a footman loop and a nylon strap to hold the fridge and closet door solidly shut.
KE4GNK/AE
Old 09-07-2015, 01:24 AM   #20
CRH
1995 25' Excella
xxxxx , xxxxxx
Child safety latches. They are little plastic things that screw inside the drawer and catch it if it slide open.
CRH is offline   Reply With Quote
Old 09-07-2015, 06:45 AM   #21
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Originally Posted by TinShack View Post
These brass catches have adjustable tension and mount on the back of the drawer. They work great and the drawers stay put when traveling. A slight tug opens it.Extruded Double-Ball Catches - Lee Valley Tools
We have a Lee Valley store a couple of miles from home, and I added those latches to the backs of the three "under-bed" drawers, one or more of which sometimes would slide out in the past.
Haven't tried it on the road yet, but it seems as though they will work - and as you say, they can be further tightened up if needed.
As well, we have occasionally had the bedside drawers jump up and slide out on really bad roads.
My "fix" for that is a simple wooden block that fills the gap between the top of the drawer front, and the bottom of the shirt cupboard door immediately above it.
The wooden block is just loose but is held in place when traveling by an aluminum bracket that goes under the mirrored shirt cupboard door and is trapped in place when the shirt cupboard door is closed.
With this little gadget in place for traveling, it makes it impossible for the drawer to jump up, so it cannot slide out.
Should work - haven't tried it on the road yet either though!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
drawers won't open panora2 General Repair Forum 5 06-07-2013 11:57 AM
Drawers come open when travelling mhilley Wheels, Hubs & Bearings 13 11-22-2010 10:49 AM
Drawers open while in transit mhilley Doors & Locks 15 10-08-2010 09:51 PM
Kitchen drawers-can they support weight? femuse Cabinets, Counter Tops & Furnishings 7 10-29-2004 06:13 PM
They don't make them like they used to femuse Our Community 23 04-29-2003 07:15 AM
