Old 04-16-2018, 08:12 AM   #1
2014 28' Land Yacht
Santa Rosa , California
Refrigerator/electric help
Iím replacing a household refrigerator from previous owner with a dometic 1350. Behind the fridge Iíve found an unknown black and yellow set of wires capped off w/ wire nuts. Looks to be 12 gauge wire but in corrugated sleeve but not in the typical yellow or white rubber housed wire insulation. Not hot with ignition off. Does anyone have an idea what it is? Already have two plug wires there. This is a third that originates from front and under slide out. Canít trace it further.
Carman is offline   Reply With Quote
Old 04-16-2018, 08:45 AM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Probably solar panel pre-wire. In the past yellow has been the positive for the panel (yellow - sun, get it?) and black the negative. The refrigerator area is a typical location to bring it out. That's where mine is. You cold confirm this in your manual. If you don't have one, you can download it at Airstream.com.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 04-18-2018, 06:49 AM   #3
2014 28' Land Yacht
Al
Thanks. Appreciate the reply. Frankly, I was hoping someone would say it was a 12v dc wire for my replacement Dometic because I havenít located it yet. Curious thing is the solar is operating fine. These wires are just terminated with yellow wire nuts in the refrigerator enclosure.
Atwood LP/Electric Water Heater Problems (Electric Has Failed) gquake Water Heaters, Filters & Pumps 10 06-29-2014 03:02 PM
For electric for genration hase to be oun for electric RichardT Electrical - Systems, Generators, Batteries & Solar 7 12-05-2005 08:05 PM
Propane/electric refrigerator B Stover Refrigerators 6 10-25-2005 12:01 PM
Propane/Electric Refrigerator jlh Refrigerators 4 09-19-2005 03:53 PM
Electric or Gas electric fridge replacement?? tin can luv Refrigerators 26 03-22-2004 09:50 AM
