Old 05-09-2016, 11:30 AM   #1
1984 31' Excella
Kingwood , Texas
Rear Twin Beds
I'm looking for a set of rear twin bed frames. I bought a 31' Excella with a rear bedroom without frames. Any help or direction would be appreciated.
Capt. Chris is offline   Reply With Quote
Old 05-09-2016, 07:44 PM   #2
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
I wouldn't call what we have as frames. There is a front facade that has three roll-up doors with bins inside. Then there are about five aluminum rectangular slats that bridge between the wall and the front facade. Two are hinged so that the plywood top can be lifted to allow access.
I hope this helps.
sgschwend is offline   Reply With Quote
Old 05-09-2016, 07:56 PM   #3
1987 25' Sovereign
Oregon , Ohio
My 87 Sovereign has the same things as sgschwend has.
msmcv51 is offline   Reply With Quote
Old 05-10-2016, 11:24 AM   #4
1984 31' Excella
Kingwood , Texas
Thank you! The picture helps. I do have the front piece but no aluminum cross members which I can pick up at my local metal supply.
Chris
Old 05-10-2016, 11:37 AM   #5
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
The fronts are easily constructed with a little sanded plywood. Use the the same plywood to make the cross members instead of aluminum.
Make slab doors hinged on the bottom and lay on the floor in the open position.
The new trailers are all plywood and fiberboard.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 05-10-2016, 08:02 PM   #6
sgschwend's Avatar
1986 25' Sovereign
Images: 13
The bed in the picture I stretched to make it a full width twin, the other side is the 34" wide AS size.
The make mattresses now with inner springs, we purchased two and will open up the sewn seam and change the shape to a curve. The inner springs make this possible since they are not connected to the adjacent springs.
Removing rear twin beds Bud Brown 2001 Safari 3 05-25-2013 09:47 AM
replace twin beds in rear bedroom update femuse General Interior Topics 7 03-24-2003 09:25 AM
replace twin beds in rear bedroom femuse General Interior Topics 12 02-28-2003 01:43 PM
Twin rear beds DClark General Interior Topics 15 11-24-2002 08:49 PM
