Old 09-20-2010, 12:02 PM   #1
1972 31' Sovereign
Townsend , Georgia
Range hood blues
Hi all and thanks for any help.
Bought the A/S but the range hood has no guts or exhaust pipe, just the filter assembly on the underside of the cabinet. Have been unable to locate. Need desperately cause we live here full time and cook three squares daily.
Again, thanks
avisjean is offline   Reply With Quote
Old 09-20-2010, 12:27 PM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Again, thanks
Mine is a newer unit and the range hood exhausts straight back fro the hood through the sidewall. I know some of the older ones go upward through a cabinet and exhaust on the roof. If yours goes out the side, you can probably pick up a whole new(er) unit from a salvage yard. Brand new? Camping World. These were never unique to Airstream, but were bought as components to many RV's. Just start making some calls. If yours is one with the stack, try Colaw's Salvage - they are on the web - and have many wrecked Airstreams.
BTW, many people have bought stock fans from J.C. Whitney, etc. to replace burned out ones. As for the duct work - it might be possible to have it made at a local sheetmetal shop, or even fabricate it from stock stuff you can get at Home Depot.
Best of luck, Paula
Old 09-20-2010, 01:09 PM   #3
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
Adapt automive 12 volt stuff until you find replacement equip.
If using shore power(120v) most of the time when cooking...Mobile
home parts ore plentiful and inexpensive ... another adaptation...
having nothing - it time to adapt and be smoke free
kennethowens is offline   Reply With Quote
Old 09-20-2010, 01:19 PM   #4
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Again, thanks
OK.... being not so sure of what unit is installed in your rig and not really sure what you are asking help on other than you cook three times a day and are in desperate need of help. Is it your cooking that needs help? Unable to locate; locate what? Let's get the blanks filled in and I know lots of folks will chime in to help you. We can't help too much with your cooking but probably can help with your range hood. Does the fan go on when you flip the switch? It most likely is a recycling fan unit which means it does not vent outside. I can be easily replaced with an outside venting unit if you are into cutting both the interior and exterior walls, making an insert between the walls etc. We did this in the 1960 Tradewind and not only does it vent very well we were able to add a bunch of insulation to that wall section while doing the upgrade. If you decide not to bring out the tin snips, the best thing to do is take out the filters and clean them and the interior of your existing unit often.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 09-20-2010, 01:51 PM   #5
1986 25' Sovereign
Plant City , Florida
I don't know the answer to your question but maybe I can clear some of the confusion for others;
The OP is looking for the vent box and tubing as well as the blower and motor for the exhaust system over the stove.
I am sure Inland Andy can help with parts.
Chris
ck21084 is offline   Reply With Quote
Old 09-20-2010, 01:52 PM   #6
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
A Fantastic Fan in the closest overhead vent will work.
Old 09-20-2010, 02:06 PM   #7
2005 22' Safari
1960 24' Tradewind
If all you are looking for is replacing the current unit with a ventless fan check this out.
RV Range Hood - Stainless Steel & Ductless
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
2004 22' Safari
1960 24' Tradewind
Old 09-20-2010, 02:09 PM   #8
2005 22' Safari
1960 24' Tradewind
Double Thread
Looks like you have two threads on the same subject going here.
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
2004 22' Safari
1960 24' Tradewind
Old 09-20-2010, 02:14 PM   #9
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The two threads have been merged into one...
Richard
Old 09-20-2010, 06:02 PM   #10
Splitrock's Avatar
Sioux Falls , South Dakota
Again, thanks
I got a raging anxiety attack from reading your post and I ran outside in my shorts and one slipper to check my vent because I've never tried it. All I could think all the way up the hill is that the fan will not be there. I pulled the filter down and there's a cable to pull the door down and a fan and it worked. This might be the first thing that I've tried that actually worked.
Gary
range hood
Baraldi Range hoods, The Stainless steel Range hood found in 2009 Airstreams AeryCorp Commercial Listings 18 05-10-2016 01:41 PM
Range hood 67twinkie Stoves, Ovens & Microwaves 24 04-06-2015 10:30 PM
does anyone know of a range hood that... Julie R Stoves, Ovens & Microwaves 12 08-13-2007 10:00 PM
Oven/Range Hood kneal Stoves, Ovens & Microwaves 2 01-10-2007 04:01 PM
Range hood C Johnson Stoves, Ovens & Microwaves 0 05-30-2005 01:35 AM
