Old 01-22-2010, 06:44 PM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
POR 15 Marine Clean?
Has anyone on the forums tried cleaning with Por 15 Marine Clean. Any concerns using this? Saw a post where Por 15 actually removed the paint from a Harley. How does this compare to Krud Kutter. Thanks!
Roadrunner is offline   Reply With Quote
Old 01-22-2010, 08:05 PM   #2
Mexray's Avatar
1978 28' Ambassador
Morada , California
Use it all the time - it's much better that KK, IMHO - I've tried them both and POR is the clear winner!
I got the POR to clean the interior vinyl walls of our AS, and it's the only stuff that worked for us...you have to use lots of ventilation, otherwise it's fairly benign...
You can dilute it with clear water for varying degrees of 'dissolving power'...the flush or wipe the project with plain water to finish!
Ray
Ray & Pat; Morada, CA
Product to clean stovetop? karenjude Stoves, Ovens & Microwaves 2 02-03-2014 07:36 PM
Clean Belly RTurnConn Belly Pans & Banana Wraps 4 08-30-2011 09:22 AM
Old Water Tank Removal & Clean up IronGiant Fresh Water Systems 9 06-23-2011 07:53 AM
Newbie ? Home sewer clean out Bigcgar On The Road... 15 04-30-2011 05:55 AM
