Old 06-01-2016, 09:16 AM   #1
1960 Caravel
Issaquah , Washington
Polish away or...?
What has everyone found to be the best way to remove this hazy stuff? I have a bit more of the interior paint to remove (the whiter spots around the rivets), but the haze isn't coming off at all. So far I have used more paint stripper - Citristrip - and paint stripper finisher, which has removed a fair bit of what I have been trying to get rid of. So would polishing be the best way to get rid of it or is there another way that would better? The ultimate goal is to have a shiny interior with painted endcaps.
Jake Holt is offline   Reply With Quote
Old 08-02-2016, 04:20 AM   #2
1972 31' Sovereign
Smithville , Texas
They make polish just for that. I think one is an abrasive and then you come back and buff it--not by hand. My dad bought the stuff from an airstream parts/repair place (Crestview RV in Buda, TX I think is who he goes to), and I believe it was a two step process. This was yrs ago, so it's hard to remember, but if you can't find anything online, they ought to be able to tell you. I have seen the old ladies all polished up, and they go from really cloudy to gleaming. Good luck!
SoverignGal is offline   Reply With Quote
Old 08-02-2016, 07:21 PM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Wet sand with progressively lighter grades. Take it easy so you don't cut too deep. Then use the Jestco method. Go to Jestco.com to see it ..their method may work for you without sanding...but wet sanding will remove the hard to shine stuff.
1966 Overlander
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
Our AIRSTREAM and TIN CAN TOURIST Rallys
Old 08-16-2016, 10:05 PM   #4
1960 Caravel
Thanks I'll look that up. Have some time before I can get to work on it again. Trailer's currently still in Michigan, and I'm n Washington.
Old 10-07-2016, 05:10 AM   #5
Goliad , Texas
yes wet sanding
Yes this will probably do it. This is what I did to rid my self of the corrosion and haze. You may never get rid of all of the pits.
Start with 800 grit and give a couple of passes all the time making sure you are keeping the area wetted and paper washed off. Have wet cotton cloth or better yet micro fiber to clean surface. Then proceed to 1000 or 1200 grit and give that a couple of passes. I then did a couple passes of 2000 grit to remove most abrasion marks.
Clean with mineral spirits and inspect. If you think you have gotten the results you are happy with you can proceed to polish. If not go back to sanding
I then use the Nuvite line of polish. With above steps, I do one pass of G6, then C until most scratches are gone and then S for final polish
Use only aluminum oxide sanding medium. Usually can find at auto restoration stores
The Frommes
Goliad, Texas
The Birth Place of S. Texas Ranching
WBCCI #6256
eartick is offline   Reply With Quote
Old 10-07-2016, 12:19 PM   #6
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Polishing the interior isn't much different from polishing the exterior. The "haze" is oxidation that needs to be removed. Sanding (even wet sanding) is a pretty aggressive way to do so. Check out the exterior polishing posts for other methods that you may want to consider. We have found the less aggressive you are in the compounding stage, the easier it is to bring out the "mirror finish" in the polishing stage(s).
Shari
To polish or not to polish? Globie64 Cleaning, Stripping & Polishing 2 08-24-2012 01:20 AM
half polish, dull, or matte, polish techniques ? greenrig Cleaning, Stripping & Polishing 9 07-11-2009 11:11 PM
to polish or not to polish that is the question Frank's Trailer Works Cleaning, Stripping & Polishing 17 08-26-2007 12:15 PM
To Polish or not to Polish, that is the Question? mello mike Cleaning, Stripping & Polishing 14 03-22-2005 12:28 PM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 08:15 AM
