Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum
Old 07-05-2002, 09:11 PM   #1
Dennis's Avatar
Profile:
Plastic Wheel Wells
After removing most of the interior and the appliances, I discovered that the plastic wheel wells were shot and do not keep the road dust and dirt out of our '73 GT. I would appreciate any information anyone could pass along regarding replacements that might be available.
Dennis.
Dennis is offline   Reply With Quote
Old 07-07-2002, 11:38 AM   #2
Profile:  LOST , Hawaii
Mine were the same. Used them as a mold to make new fiberglass ones. Much stronger and pretty easy.
74Argosy24MH is offline   Reply With Quote
Old 07-09-2002, 01:18 PM   #3
Dennis's Avatar
Profile:
Thank you
To 74Argosy24MH
Thanks for the info. As much as I hate fiberglass, I guess that is about my only answer.
Thanks again
Dennis
Old 07-09-2002, 01:29 PM   #4
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
If you wanted to you could look into using sheet abs and making your own, but you would need to lean a new skill or buy a bunch of tools to heat and form the abs. The sheets can be bought in 4X8 sizes and in various thicknesses. I want to say a 4X8 sheet at 1/4 inch thick is less than $50.00. It can be cut on a table saw but I have not yet learned all I want to know about how to heat and bend or form it. I know it can be vacum formed and there are machines you can buy for small projects but I think wheelwells would qualify as a big project.
Brett G
WBCCI #5501 AIR # 49
Logic is the one way you can go wrong with confidence - Charles E. Kettering
Old 07-10-2002, 06:59 AM   #5
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
You can also use sheet aluminum and rivets to make new ones. They don't have to be perfect as they are hidden and all they really do is keep the dust and spray out. Aluminum will never rust and be come brittle.
You only need to cut 2 pieces for each one. Cut one long one for the top and short sides and one for the inside side. Leave enough material on them to form riveting flanges. Use the plastic wells for a pattern. Seal it up with Vulkem or Par-Bond
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 07-10-2002, 10:42 AM   #6
Commercial Vendor
Profile:  Corona , California
Bobby.
Airstream quit using the "metal" wheel wells many years ago. The problem was owners would not keep the running gear properly balanced and as a result of that the metal quickly fatigue cracked. Then they went to a inexpensive plastic, and the same thing happened. As a result of those failures, a much heavier formed plastic was used sometime back, and the results have been excellent.
I have no info on fiberglass replacements.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 07-10-2002, 01:29 PM   #7
83Excella's Avatar
Profile:
Wheel wells
But it does not stop a blown tire and/or thrown treads from destroying it and the area around it. Dennis have you contacted your local dealer on price and availability of them?
John
83Excella is offline   Reply With Quote
Old 07-10-2002, 04:55 PM   #8
BobbyW's Avatar
Houston , Texas
Andy;
So can the new ones be used on the 60's and 70's trailers. This would be a boon for the restorer.
-BobbyWright
-BobbyW AIR# 123
-Red Green
Old 01-14-2003, 01:55 PM   #9
hex
hex's Avatar
Profile:
Question Another hanging thread...
Well...?
So can the new ones be used on the 60's and 70's trailers..?
And has anyone ever identified the year that metal wells were discontinued?
hex is offline   Reply With Quote
Old 01-14-2003, 06:31 PM   #10
Dennis's Avatar
Profile:
Thanks to all for the suggestions. Since I am kind of a simple guy, I went ahead and made them out of 3/8 plywood and they were pretty easy to make. I have been away for a while but am about to bring the unit inside my garage to finish the interior.
Thanks again for all the help.
Dennis
Old 01-14-2003, 10:34 PM   #11
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Dennis,
Are the wheelwells cracked or crumbling? I have heard of people have the underside of their riding lawnmower decks sprayed with Line-X to prevent rust. These are the same people that spray truckbeds and floors of Jeeps, horsetrailers, etc. I wonder if your wheelwells could be sprayed both sides to give them some strength but don't know if it would work.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-15-2003, 09:29 AM   #12
Commercial Vendor
Wheel wells consist of an "inner" and an "outer" cover. Spraying the outside could offer some strength, but not enough to prevent damage from a tire blow out or from an oversize tire or from a tire that is on a worn out axle.
The plastic covers, to a large degree are not damaged from tire vibration, such as happened with the metal covers.
Restorers that switched to "wood" covers will usually find that in time, they become loose because of vibration, and the normal twisting from the floor and shell.
Not impossible, but very rarely can we "out engineer" the Airstream factory.
Had todays technology been available to us or Airstream 30 and 40 years ago, it would have been used.
Retro fitting when a major restoration project is undertaken, is always the smart way to go. From it, we all learn.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-15-2003, 09:52 AM   #13
Dennis's Avatar
Profile:
Craig
I don't know if the spray on stuff will work or not. I would imagine that since the material seems to be somewhat flexible, it might help to keep the wheel well together.
Dennis
Old 01-16-2003, 11:42 PM   #14
davidz71's Avatar
Dennis,
The Rhino Linings seems to have a more rubbery feel and looks more like cottage cheese than the Line-X which is harder. My son had his tailgate sprayed with Line-X and threw a big rock onto it. It put a slight dent in one area but the surface was not cracked. It will slice just like the other spray-in liners but Line-X claims it closes up (doesn't sound right). I will have the bed of my '01 sprayed this summer with Line-X because I have seen a shovel used on it and it is tough. Visit the Line-X website and maybe they will mention if it can be sprayed on plastic. Hmmmm, that might be interesting for the plywood flooring in the storage compartments but don't know if there is enough room for the spraygun to work.
Craig
AIR #0078
3.73 rear end
Alternate exterior plastic parts repair IPM Bumpers & Bumper Storage 2 01-24-2008 11:46 AM
**Broken Wheel Well** Silvertwinky Wheel Wells 8 05-26-2006 03:57 PM
Wheel Chocks pjtaia On The Road... 13 10-28-2005 03:27 PM
Wheel lockup erstrong Brakes & Brake Controllers 2 10-07-2003 01:52 AM
Dolly Wheel brunoffrance Towing, Tow Vehicles & Hitches 4 01-02-2003 06:35 AM
