Old 07-25-2012, 06:08 PM   #1
1965 22' Safari
Rancho Palos Verdes , California
no cell phone signal inside my Safari
Does anyone have a suggestion for increasing cell phone service inside my Airstream. I also use a Verizon Hotspot that has the same problem. Is there an antenna that could help?
hollywoodair is offline   Reply With Quote
Old 07-25-2012, 06:50 PM   #2
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
Take a look at something like this:
Wilson Electronics Inc.
I have successfully used a direct wire antenna amplifier for both my cell phones, and my air cards, for several years. I also had an occasion to use the wireless setup of a friend, and it also worked fine.
If you have an external antenna connection on your phone, sometimes all you need to do is get an antenna outside of the aluminum shell to get an acceptable signal. Unfortunately, it seems that most cell phones don't have an external antenna connection these days.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 07-25-2012, 08:45 PM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Check for FBI and CIA bugs. They can block those kinds of devices
Strange as mine works fine.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-25-2012, 10:29 PM   #4
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Try to use your phone or place your hotspot next to a window. Preferably one pointing toward the cell tower, if you have any idea where it might be. If you have an Android phone, look for an APP called OpenSignal. It will help you locate the cell tower that you are using. If that doesn't work then look into an amplifier or repeater. The Wilson link posted above is a good place to start.
Ken
Old 07-26-2012, 12:18 AM   #5
2005 19' Safari
GLENDALE , AZ
If you have an antenna connector on your cell phone and hotspot device, you can add an external antenna to get a better cell signal. If you do not have these connectors, you can still use an external antenna; but you will need to purchase an induction cradle for you phone or hotspot device. In remote areas, an amplifier can also be used to boost a weak signal; although, this won't help if there is absolutely no signal to receive.
Please provide details on the phone and mobile hotspot device you have, so we can determine if they have antenna connectors. Or, you can check for connectors yourself. Then, we can provide more detailed assistance.
Link to Wilson Sleek induction cradle, amplifier and external antenna kit:
Sleek 4G-V Wilson Electronics 4G LTE Cell Phone Signal Booster - 815125 - 4GV, 10 Reviews : 3Gstore.com
Note: Above link is for example purposes only. Other devices may work as well or better, and be cheaper from other sources.
Old 07-26-2012, 07:15 AM   #6
Wayward's Avatar
Cary , North Carolina
My Safari seems to be a big cell phone signal block. I even have trouble with weak wifi inside. If I move outside the trailer it is often a bar or two better. I think it is the double wall aluminum skin?
I added the Wilson 18" Shorty through-roof RV antenna. It does not need a ground plane like many trucker antennas. It is mounted on the refrigerator vent cap and the cable runs down through the existing vent hole (no new hole to drill in skin).
The antenna was a huge improvement! I use it for the cellphone and for the ATT Elevate hotspot. So far I've not needed a signal booster. Just double check that you get the right antenna length for your carrier frequency bands.
As Phoenix mentions, phones, cellular modems or hotspots with external antenna connectors work best with the antenna, but you can get a cradle if your phone does not have one.
Once you get the antenna set up maybe consider a wired or bluetooth head set, cordless phone, or speaker phone so you are not limited by the antenna cable.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
