Pull the cabinets and sofa out and do the complete floor. If you install any of the prefinisher flooring they will not be effected by the replacement of the cabinets.
Just remember that any cabinets that will be screwed down through the floor you should drill a 1 in. clearance hole where the screws will go. This alows the flooring to float.
Removing the cabinets reduces the need to install 1/4 round around them. A cleaner finish look.
2004 Excursion 4x4
