Old 06-08-2014, 12:16 PM   #1
1975 31' Sovereign
Davin , West Virginia
Need help locating fuse on Armstrong TR21-12 air conditioner
An electrician mistakenly wired our new 30amp receptacle for 240v instead of 120v. Plugged in and tried the a/c. Nothing happened, so I checked all the breakers inside the trailer to find none were tripped. Went inside to heck the breaker there and noted that it was a double breaker, so I turned it off and disconnected the shore power cord. Now the heating element in the refrigerator is ruined, and the a/c still won't run. The plate on the unit says it must be protected by a fuse. Someone had posted a service manual for a 25-12 that mentions a 20amp, slo-blow fuse. I'm thinking I might get lucky and find a fuse blown, but I don't know where to look for it. Anybody have any ideas?
Hillbilly75 is offline   Reply With Quote
Old 06-08-2014, 01:07 PM   #2
The "only" protection that the AC has, is a circuit breaker.
Circuit breakers, sometimes seem OK, but can be shot.
Best way to find out, is to remove the circuit breaker panel and check to make sure that each circuit breaker has an output when in the on position.
The AC never had an internal protection, when new. Someone of course could have changed that.
Old 06-08-2014, 02:36 PM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I don't know where a fuse might be, but my bet is that the very first part that pops when double voltage was applied would be the 24v AC transformer.
If this is so, and that is all that popped you will get out pretty cheap and easy.
Old 06-08-2014, 02:38 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
The a/c was on a double breaker?
Really ? I imagine the same electrician wired the breaker too?
Old 06-08-2014, 02:41 PM   #5
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
If it is still wired on a double breaker, that means the wiring in the box is still screwed up, and you cant know for sure that your a/c is even hurt.
Old 06-08-2014, 04:00 PM   #6
1975 31' Sovereign
Yes, a double breaker. It was installed new just for the receptacle. Now I have gone back to my 15amp outlet with adapter. Is that transformer on top or inside the ceiling?
Sent from my HTC PH39100 using Airstream Forums mobile app
Old 06-08-2014, 04:24 PM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The transformer is under the shroud, with what look almost like automotive wires going to it.
In 1975, some models have a separate switch for the unit and fan, generally on the ceiling assembly, and a remote thermostat. Are you sure the fan switch is "on"?
Old 06-08-2014, 05:12 PM   #8
1975 31' Sovereign
I don't see any switches on the unit. The thermostat has two fan speeds on it, and an on/off switch. I'm guessing the transformer will either look burnt, or somebody can tell me how to check it with a meter. Got really lucky on the fridge- hoping the a/c is a simple problem too!
Old 06-08-2014, 06:06 PM   #9
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
It probably looks something like this.
It may show visible damage or it can be blown and look fine.
http://www.bing.com/images/search?q=...F0CD1&first=23
Old 06-08-2014, 06:35 PM   #10
Well Preserved
1993 21' Sovereign
If you have the on/off switch and high/low switch on the thermostat, you won't have a separate switch on the ceiling assembly.
Make sure you check the converter for proper output, also. Even though it may be humming, it may have burned out internally.
Old 06-08-2014, 07:01 PM   #11
1975 31' Sovereign
I wondered about the converter also. It is one of the new progressive dynamics ones with "charge wizard". I'll have to get out the manual on it, but I'm pretty sure it has a built in over-voltage protection. Thanks for the picture! That will help me out a lot. I think I know approximately where to look now. Is the replacement going to be pretty easy to come up with? I'm guessing either a HVAC parts dealer or Radio Shack?
Old 06-08-2014, 08:16 PM   #12
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
If it is the transformer, a HVAC shop or a place like Grainger, or even an electrical supply store will have a transformer.
The transformer wont have to look the same , it will just have to have the same input and output voltage and amps, and of course it will need to fit in the space.
Old 06-08-2014, 08:52 PM   #13
1975 31' Sovereign
Sounds good. Hoping to get to look at it tomorrow after work.
Old 06-28-2014, 03:28 PM   #14
1975 31' Sovereign
Found the transformer today and checked it with a meter. With shore power unplugged I get almost perfect continuity between the two terminals of the transformer, as well as between the terminals of the relay in any combination. Plugged in and turned on at the thermostat, I read no voltage anywhere. Going back out this evening to see if I can get the breaker out of the box and check it. It's a bear to get to-- under the water heater cabinet and partially hidden by a shelf.
Armstrong TR21-12 Help Please? Gael79 Furnaces, Heaters, Fireplaces & Air Conditioning 39 06-28-2016 05:16 PM
Pls help with locating fuse box brainatplay Sprinter and B-van Forum 2 10-18-2013 10:19 PM
Armstrong TR21-12 gonna fixey ??? pansy Furnaces, Heaters, Fireplaces & Air Conditioning 1 05-08-2008 07:08 AM
Schematic wiring diagram for Armstrong AC TR21-12, GO7series DMC Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-06-2007 12:01 PM
Hello, looking for a schematic of the wiring in my Armstrong AC model TR21-12, DMC Member Introductions 1 07-10-2007 06:11 AM
