Old 11-24-2013, 05:57 PM   #1
ASNomads's Avatar
1978 28' Ambassador
Byfield , Massachusetts
Need Aluminum Adhesive
Hi all,
I am looking for an metal/aluminum adhesive to glue Prodex bubble wrap insulation to the inside of my interioir panels. The insulation is coated with aluminum foil so essentially it would be an aluminum to aluminum bond.
Any recommendations?
Georgie
ASNomads is offline   Reply With Quote
Old 11-24-2013, 06:19 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have used Weldwood Contact Cement to glue Reflectix to interior walls. I also tried spray adhesive, but like the Contact Cement better.
Old 11-24-2013, 06:21 PM   #3
2002 19' Bambi
Lafayette , California
3M 90 spray adhesive. Best known is 3M 77 spray adhesive, but it does not stick as well nor is it as heat resistant as the 90. Here is a listing on Amazon: 3M 90-24 Spray Adhesive 17.6-Ounce - Amazon.com
Tim
Tim A. is offline   Reply With Quote
Old 11-24-2013, 07:23 PM   #4
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
3m 5200
Lance
Top is offline   Reply With Quote
Old 11-24-2013, 07:27 PM   #5
DFlores's Avatar
1968 22' Safari
I am using carpet tape from Home Depot, works for me.
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 11-24-2013, 10:42 PM   #6
1950 Flying Cloud 7039
FC7039's Avatar
1950 21' Flying Cloud
Allen , Texas
The aluminum foil will work as a radiant barrier but not where it is in contact. I am not sure where and why you would want to glue it. I would just use foil tape at the ribs a let the be space between the skin and insulation. It will touch in areas. You can put it spacer or leave it. But why force it to be in contact with the skin. Sorry I know you were only asking about glue and not my opinion
FC7039 is offline   Reply With Quote
Old 11-25-2013, 05:34 AM   #7
65CV's Avatar
Western , Massachusetts
In my experience, PL Adhesive worked very well. I glued strips of prodex to the panel, then glued a full prodex layer to the strips, forming air gaps. After a full winter and nearly a full summer, I cut an access panel and found that the adhesive was still bonded quite well. Details start at post 144 in this thread.
65CV is offline   Reply With Quote
Old 11-25-2013, 07:04 AM   #8
Lumatic's Avatar
1993 34' Excella
Images: 16
Reflectix, and I suspect Protex, work best with dead air spaces with the edges sealed to trap the air.
Old 11-25-2013, 07:08 AM   #9
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
I used nails. Seems to keep kids from leaning againt the trailer too.
robwok is offline   Reply With Quote
