Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum
Old 04-14-2008, 04:39 PM   #1
jlester
JLester
Profile:  1962 19' Globetrotter
Canyon Creek , Montana
Metal surface that can hold a magnet
I am wanting to use a metal for my refigerator door and backsplash around the stove that can hold a magnet. Has anyone figured this out yet?
jlester is offline   Reply With Quote
Old 04-14-2008, 04:57 PM   #2
Aerowood
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
Yes, Use ferrous metal
Old 04-14-2008, 05:18 PM   #3
markdoane
Profile:  , Minnesota
Images: 59
Ferrous metal?
I guess that’s made from ferrets?
Non-contributing deadbeat.
Old 04-14-2008, 05:20 PM   #4
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Simply put...
...most common steel-like metals EXCEPT aluminum. They have to have some iron in them...
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Old 04-14-2008, 05:24 PM   #5
Jaxon
E Pluribus Aluminus
Jaxon's Avatar
Profile:  2005 30' Classic
The cowling around the vent above the stove in ours holds all sorts of magnets... Unless you replace the aluminum with steel or the likes, you're outta luck using magnets.
Bill & Kim's Marvelous Adventure
with Catahoula Charlie
F250 Diesel Lariat Crew, SWB
30' Classic Airrrstreeeamm
AIR 9218
"When the only tool you own is a hammer, every problem begins to resemble a nail...." Maslow
Jaxon is offline   Reply With Quote
Old 04-14-2008, 05:49 PM   #6
cosmotini
cosmotini's Avatar
Profile:  2008 27' International CCD FB
Highland , Illinois
Images: 83
Smarta$$ answer
Put double stick tape on the magnet
Dennis
Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Old 04-14-2008, 06:16 PM   #7
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
They haven't perfected aluminum made from steel yet, but you may be able to slide a sheet of thin steel behind the aluminum, and the magnet will grip the steel through the aluminum.
Change is inevitable, except from a vending machine
AIR#2611
Old 04-14-2008, 07:25 PM   #8
robert claus
Profile:  2000 19' Bambi
mt. Prospect , Illinois
Go to a sheet metal shop and get some 400 series stainless steel in what ever gauge you need. 300 series is non magnetic, but 400 is not. Take a magnet and try sticking it to different s.s. appliances around your house, and you'll see that it will stick to some and not to others, sometimes even different parts of the same appliance will differ. Manufacturers will use 400 series when they can because it's a bit cheaper. However, in exterior applications it can get rust spots on it, so 300 series would be used there.
robert claus is offline   Reply With Quote
Old 04-18-2008, 09:26 PM   #9
jlester
JLester
Thank you very much. I will start calling around.
Old 04-19-2008, 12:15 PM   #10
centennialman
centennialman's Avatar
Profile:  1966 22' Safari
Centennial , Colorado
I agree....perhaps replace the insert on the refrigerator door with some sheet metal....would that work for you?
Steve "Centennial Man"
1966 Airstream Safari - Her name is "Aunt Bee"
centennialman is offline   Reply With Quote
Old 04-19-2008, 04:37 PM   #11
dnrtheil
dnrtheil's Avatar
Profile:  1964 24' Tradewind
Portage , Michigan
My wife wanted an area in the kitchen for magnets, I purchased a sheet of thin steel from the duct work area of our local Lowes, laminated it to the wall seperating the kitchen from the middle couch with epoxy, then applied brushed aluminum vinyl over the steel. This duct work material should work for you, it was roughly 3' x 3'.
Operation "SAVE RUDY" Strike Team (Associate Member)
dnrtheil is offline   Reply With Quote
Old 04-19-2008, 07:02 PM   #12
overlander63
Images: 58
If you can find an enameled steel dry erase (bulletin) board, it would also work. You can jot down notes to each other, and hold those papers and coupons with the magnets.
AIR#2611
Metal Window Hold Strips Needed mediaetc Windows & Screens 1 04-07-2007 02:38 PM
Surface Oxidation Lumatic Ribs, Skins & Rivets 11 01-22-2007 06:28 AM
Is AS the ultimate chick magnet?? dijer Our Community 5 09-08-2006 09:45 PM
brake-magnet damage Tin Hut Brakes & Brake Controllers 1 10-21-2003 08:12 PM
Brushed Surface Help Randy Johnson Ribs, Skins & Rivets 2 05-05-2003 04:57 PM
