Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
The cowling around the vent above the stove in ours holds all sorts of magnets... Unless you replace the aluminum with steel or the likes, you're outta luck using magnets.
__________________ Bill & Kim's Marvelous Adventure with Catahoula Charlie
F250 Diesel Lariat Crew, SWB
30' Classic Airrrstreeeamm
They haven't perfected aluminum made from steel yet, but you may be able to slide a sheet of thin steel behind the aluminum, and the magnet will grip the steel through the aluminum.
Terry Aluminitis never sleeps...
AIR#2611
Go to a sheet metal shop and get some 400 series stainless steel in what ever gauge you need. 300 series is non magnetic, but 400 is not. Take a magnet and try sticking it to different s.s. appliances around your house, and you'll see that it will stick to some and not to others, sometimes even different parts of the same appliance will differ. Manufacturers will use 400 series when they can because it's a bit cheaper. However, in exterior applications it can get rust spots on it, so 300 series would be used there.
My wife wanted an area in the kitchen for magnets, I purchased a sheet of thin steel from the duct work area of our local Lowes, laminated it to the wall seperating the kitchen from the middle couch with epoxy, then applied brushed aluminum vinyl over the steel. This duct work material should work for you, it was roughly 3' x 3'.
Operation "SAVE RUDY" Strike Team (Associate Member)
If you can find an enameled steel dry erase (bulletin) board, it would also work. You can jot down notes to each other, and hold those papers and coupons with the magnets.
AIR#2611
