Old 07-06-2014, 07:06 PM   #1
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Less Wasted Space in the Airstream
As all Airstream owners know, storage space inside the Airstream is a premium. As I was trying to figure where to store my new O-Grill BBQ, I decided to reconfigure an area of the trailer that has always been wasted space. On my 27FB International Serenity, and I think true for 25FB's too, the dinette seat adjacent to the entry door is mostly wasted space. The subwoofer is back there, but it's fairly compact.
There's a large wasteful triangular shaped piece of upholstered foam occupying the space behind seatback cushion (left side looking back). The entire seating area sits above mostly wasted space except for a small slide out drawer.
The photo above shows the standard Airstream layout. Lots of cushion, not much useful storage underneath.
I decided to do something about this problem, so I started by ripping everything out.
I noticed that the slide out drawer could be larger. There's plenty of extra room between the aluminum legs and more room to the rear. It could be rebuilt to be wider, taller, and deeper.
Here's a photo of the new replacement drawer. It was an easy project to remove the laminated front piece from the old drawer box and screw it onto the new larger drawer box.
Next I cut the existing piece of plywood, the seat bottom and began laying out a shell of a cabinet that could hold the BBQ on end and a few other items. I intentionally set the seatback side of the cabinet at a slight angle to provide seating comfort. In the photo the old foam bolster is laying on top, just to illustrate how its about the same size as the replacement cabinet. I used 1/2" plywood for the cabinet sides and top and 3/4 poplar for the face frame.
Ready to be installed. I used plain white laminate for the interior and Wilsonart Asian Sand laminate (as used by Airstream for my 2013 International Serenity) for the exterior. The BBQ fits below, the top shelf is for additional storage.
Here it is, everything installed and ready to go! No more wasted space and the seat is just as it was prior to the project. I did have to get the lower cushion re-upholstered to make it shorter. The dinette still converts to a bed, just a few inches shorter than before but still more than big enough for my 6 foot frame. I wanted this project to appears as much like Airstream had made it so researched the finishes to match my 2013 Serenity. I also constructed the cabinet slightly lower than the old bolster so that it no longer interferes with the window curtains.
Parts List (Exact Airstream Match):
Laminate - Wilsonart Asian Sand - Part # 7952K-01 (Special ordered from Lowes)
Door Pull - Top Knobs Nouveau - Part # TOP_M575 (Get the part Here or Here).
The exact countertop laminate is no longer manufactured, or supplied by Airstream so I decided not to even try for a close match. I think the decision to use the Asian Sand worked out just fine.
On a difficulty level I place this project as medium high. I did have some expert carpenter help, but the project was still a lot of measuring, cutting, fitting, sanding, repeat. I'm very satisfied with the outcome and now have a convenient place to store the BBQ, shoes, and lots more.
kscherzi is offline   Reply With Quote
Old 07-06-2014, 07:55 PM   #2
Tyvekcat's Avatar
2014 28' International
Blacksburg , Virginia
awesome
I need a cabinet like that in a 28 Serenity. Mine is open like that, only on the opposite side . This Gives me an excellent idea.
awesome! Thanks so much for posting your work.
Have a good one !
Ra, Chelle & Natasha
For my next trick, I will use my new Airstream & Dodge Ram 2500 CTD to make this pile of money disappear.
Tyvekcat is offline   Reply With Quote
Old 07-06-2014, 09:07 PM   #3
Wishing's Avatar
2014 27' FB International
Arlington , Virginia
Looks amazing! Great idea to get the drawer enlarged!
Wishing is offline   Reply With Quote
Old 07-06-2014, 09:48 PM   #4
Kyle401's Avatar
1969 27' Overlander
SW , Missouri
Very well thought out and executed improvement. Great job!
Kyle401 is offline   Reply With Quote
Old 07-06-2014, 10:10 PM   #5
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Very nice....
Silverflames is offline   Reply With Quote
Old 07-06-2014, 10:18 PM   #6
mefly2's Avatar
2015 25' FB Eddie Bauer
We slide plastic storage tubs under our normally wasted space but yours looks great!
Old 07-06-2014, 10:30 PM   #7
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, this is how Airstream should have built it in the first place.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-07-2014, 12:24 AM   #8
Rivet Slave
Rocinante's Avatar
Green Cove Springs , Florida
Thanks for sharing!
I want this. A lot. It looks similar to what I saw in a 2013 27FB Flying Cloud while camping near Glacier National Park. Much better than the huge bolster and tiny drawer we have now. What was Christopher thinking when he designed that abomination of wasted space? Otherwise, though, we love our TT.
Sadly, I'm not handy enough to do this myself. I'd have to hire someone. Since ours is a Signature, we'd also need a different Wilsonart laminate color and probably a different handle to match our cabinets.
Old 07-07-2014, 04:07 AM   #9
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Beautiful- I've been eyeing that space myself. I wondered why they didn't at least put in the kind of compartment we had at the head and foot of the bed in our 20'.
On the plus side that space between the drawer and door is a good spot to stash shoes and a dog-drying towel.
I've thought of having a few oversized "cup holders" cut into the top of the foam to hold wine bottles.
2012 Dodge Durango Hemi/AWD
Old 07-07-2014, 07:59 AM   #10
Rivet Slave
Rocinante's Avatar
Correction
Correction, that was a 2013 27FB Classic, not a Flying Cloud. Here's the floorplan that shows the "chair storage" where you installed your cabinet: http://www.airstream.com/wp-content/...ifications.png
Anyway, AS should do this for all their FB models.
Old 07-07-2014, 10:08 AM   #11
drew05's Avatar
2011 25' FB Flying Cloud
Peculiar , Missouri
That's a great job!
drew05 is offline   Reply With Quote
Old 07-07-2014, 10:22 AM   #12
Anywhere & , Everywhere
Another version of a Bolster Cabinet.
http://www.airforums.com/forums/f46/...ml#post1232262
In some trailers - like the 25FB Flying Cloud - the subwoofer is located behind the drawer so it can't be enlarged.
Al - K4GLU is offline   Reply With Quote
Old 11-07-2014, 10:49 AM   #13
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We attempted that cabinet conversion to match the 27FB Classic storage cabinet by the door with the local dealership on our 2013 25FB International Serenity. It was a total disaster and had to be redone and we lost the use of the trailer for many months.
Get a competent carpenter and printout the drawings of that assembly from the Classic parts manual as guidance. The dealership did not even printout the drawings.....
Old 11-07-2014, 11:40 AM   #14
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
That is a really impressive idea and setup! Very very impressive. I almost think I want to attempt this. The gears are 'a' spinning!
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Almost a wasted Saturday DougZ 1972 Overlander 4 01-17-2011 07:22 AM
Temporarily Airstream-less FordTruck On The Road... 11 01-02-2008 09:49 AM
Airstream or less-expensive others? kenlad Our Community 12 07-18-2004 03:54 PM
