Old 06-08-2016, 12:17 PM   #1
coolbabe's Avatar
1976 Argosy 26
Lake wales , Florida
Laminate Flooring
Has anyone installed wood laminate flooring in any trailer? If so, any advice on making it right. I have a hard time cutting it without splintering. I am using a fine toothed blade and cutting from bottom even though it confuses me as to where the lips are. Does it look good when done?
Thank you
coolbabe is offline   Reply With Quote
Old 06-08-2016, 02:08 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
First off remove everything that is possible to remove. This greatly reduces cutting and fitting. Second choose a system that folds together easily. Some systems require hammering to connect. Third start on the center line of the trailer and work to each side. When replacing the cabinets over drill clearance holes in the flooring for the hold down screws and don't jam them down. In 10 years there is no evidence of any movement.
I used Armstrong flooring. Great assembly system. Hire a good assistant.
2004 Excursion 4x4
Old 06-08-2016, 02:28 PM   #3
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Run a razor knife over your cut line before cutting and youll prevent splintering. I would cut it with the finish side UP, that way your blade is cutting down INTO the wood, the teeth will blow out the back side and cause splintering. Are you using a chop saw?
mayco is offline   Reply With Quote
Old 06-08-2016, 02:46 PM   #4
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
It really helps to use a fine blade for cutting this kind of flooring. If using a table saw make sure it is not using a 24 tooth "rip" blade. A 60 to 80 tooth blade for plywood will give a smoother cut on the flooring. If using a jig saw more finer teeth will help as well.
Dennis
dennis3751 is offline   Reply With Quote
Old 08-02-2016, 03:08 AM   #5
1972 31' Sovereign
Smithville , Texas
Wow! That looks great!
SoverignGal is offline   Reply With Quote
HELP with Laminate Flooring betsy28 Floor Finishes 17 04-22-2008 02:09 PM
Laminate flooring over old VAT tiles? jadedacres Floor Finishes 16 07-24-2007 02:31 AM
Requesting Advice on Laminate Flooring Atlantica Floor Finishes 19 07-27-2006 09:35 AM
Laminate flooring up for grabs pinkflamingoes Upholstery, Blinds, Walls & Interior Finishes 0 07-11-2006 11:38 AM
Laminate Flooring Help! Safari Tim Floor Finishes 26 03-05-2005 04:31 PM
