Old 04-25-2012, 06:42 PM   #1
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Kreg Pocket Hole Jig!
I just bought one of these jigs and am giddy!
Amazon.com: Kreg K4MS Jig Master System: Home Improvement
It's the best thing since sliced bread. I want to shout it from the rooftop that this jig is the BOMB!! I don't know what woodworking hole I've been in, but I still have my ancient jig that uses dowels. It's going on the vintage woodworking auction!!! Just sayin'!!!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 04-25-2012, 06:56 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I share yur joy, even though I haven't the foggiest idea what you are talking about .
Old 04-25-2012, 07:02 PM   #3
Becky B.'s Avatar
1964 17' Bambi II
Ha! Ha! If you ever build anything out of wood that needs joining, you'll think back on my joy & wish you had one!!!
Becky
1964 Bambi II
1988 Avion 32S
Old 04-25-2012, 07:13 PM   #4
Central , Mississippi
I've been using one during Dolly's refirb. The only challenge I've had is holding the faces flush when driving the screw. Square it up, LOTS of clamps on a sturdy surface help alot.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 04-25-2012, 07:20 PM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Becky, I know where you are coming from!!!
I got dowel jigs, drill press, 2 plate joiners, mortising bits, but when I drove my first screw into a oak face frame and watched how tight it pulled up I knew the old stuff was history for a lot of uses.
Have been using the Kreg for several years now and still finding new applications for it.
HiHO...Do you have the Kreg clamp for holding the joint? It is a vise grip with round plates mounted on it and it does a super job of holding the faces flush and in place while you dirve the screw. And the joints are sorta self squaring if you make a square cut to start with. You pretty much need everything that comes in their kit to make it work well. I pretty much just lay the frame loose on the bench with a corner overhanging and use the Kreg clamp. Takes about 30 seconds to line it up by hand and close the clamp.
Bill M. is online now   Reply With Quote
Old 04-25-2012, 07:21 PM   #6
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
I agree that holding the pieces flush is the biggest problem, but I believe that Kreg has a clamp which solves that problem.
Bill
Just my personal opinion
Old 04-25-2012, 07:23 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I really like the Kreg system. I always try to clamp both pieces firmly to a flat surface before driving the screw.
Old 04-25-2012, 07:24 PM   #8
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
It works great. I have been using one in my woodshop for a couple of years. I got mine at one of the traveling woodworking shows.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 04-25-2012, 07:36 PM   #9
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Totally Agree
Becky, you are absolutely right. I have been making cabinets for years...it wasn't until I ran across the Kreg Jig that the whole process became faster and more efficient. In the recent restoration of "Island Girl" I rebuilt all the cabinets using the Kreg Jig. What an awesome tool. Picked mine up at Lowe's. I'd recommend it to all thinking about making their own cabinets.
ID:	156762   Click image for larger version
ID:	156764   Click image for larger version
ID:	156766   Click image for larger version
Roadrunner is offline   Reply With Quote
Old 04-25-2012, 07:38 PM   #10
Don't get me wrong...I'm with Becky on this being a cool tool!...the only weak link I have found is if you rely on the screw to pull the joint up tight, the offset angle of the screw WILL pull an offset in the joint.
The joint has to be clamped flat and tight...then it's 100% success!
A final thought...thick glue in the joint can cause the same problem...it has to be clamped tight, if the screw compresses the glue the joint will offset.
Old 04-25-2012, 09:15 PM   #11
CanoeStream's Avatar
St. Cloud , Minnesota
Yep, key comment there Vernon.
I'm surprised how often I use my Kreg in rough framing when I need exacting results. But it really shines to produce strong finish work.
5 meter Langford Nahanni
Old 04-25-2012, 09:28 PM   #12
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Get the Kreg clamp. It has big round faces and holds the parts square. Well worth the cost and it can be used for many other things.
John W. Irwin
WBCCI #9632
Old 04-25-2012, 09:37 PM   #13
Pahaska's Avatar
Hays County , Texas
By the way
Kreg has two sizes of drill bits. The larger size uses the washer-headed screws. For smaller work, the smaller bit size uses the smaller-headed screws and can be used in work as thin as 1/2" thick. The bit guide for the larger bit size is blue and the guide for the smaller bit size is black.
I often use the smaller size in cabinet doors where I am going to rout a notch for a plywood back. I can place the smaller holes closer together to leave more clearance for routing.
John W. Irwin
WBCCI #9632
Old 12-14-2012, 06:33 PM   #14
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Can anyone recommend which kreg jig to get?
I'd like to be able to build some cabinets bed framing etc.
I'm guessing the master system at $150 is going to be the one but I'd like to hear what you guys have. Less expensive would be nice.
Woodworking is totally new to me so excuse my ignorance.
Mike
desertair27 is offline   Reply With Quote
