Old 12-15-2012, 05:10 PM   #29
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I really like the K4 that has the clamp that you put your wood into to drill. I got the whole master system, but really don't use the loose jigs (like the R3) The clamp of the K4 holds everything pretty square (of course you have to make sure you cut it square & place it in the clamp squarely ) I have a couple of face clamps that I use on the framing. You really need to clamp everything down squarely to get a nice joint. I have one of the right angle clamps, but only used it a couple times.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 12-15-2012, 06:04 PM   #30
K4 looks like the ticket..
I went to look at YouTube vids on the K4 and that sold me on the system. My son has the biscuit joiner, etc, and that is nice, but the Kreg looks like a simpler system.
And I see the corner joint is the one that would be most useful.
Steve
Sav'h Steve is offline   Reply With Quote
Old 12-15-2012, 06:54 PM   #31
Splitrock's Avatar
Sioux Falls , South Dakota
This is a custom made copy of a Ritter square clamp table.
Old 12-15-2012, 07:16 PM   #32
Central , Mississippi
Originally Posted by beckybillrae
... Did you put a bevel on the top side of your upper cabinet frames so they sit flush on the roof? If so, have you any idea what the degree of bevel you used? Also, how did you attach the upper cabinets .,,.
I measured the angle, then added 5 degrees so the outer edge was nice and sharp...
Sheet metal screws pull up nice and tight, the aluminum snugs up and the extra angle allows for some tension. I also used the round cove plastic bead from VTS in the joint.
So far, so good!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 12-16-2012, 11:32 AM   #33
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Ceiling/Frame Bevel Angle
Becky...the angle is about 15 deg. I would set that angle on your table saw, if you have one, or use a bevel gauge and hand plane. As you can see from my finished cabinets, they don't hang straight down but have a slight tilt toward the wall. If you want your cabinets to hang straight down, I would try a 10 deg angle or less. Good luck!
Indiana, PA
TAC PA-5
WBCCI 4871
Name:	Bevel Guide1.jpg
ID:	174730   Click image for larger version
ID:	174732   Click image for larger version
Roadrunner is offline   Reply With Quote
Old 12-16-2012, 12:10 PM   #34
Becky B.'s Avatar
1964 17' Bambi II
Thanks, Bob & Vernon too. I'll give it a shot after Christmas. I'm trying to hold down the dust until after the parties at my house are over. At least I know in my mind how to go about this now. I can stop staring at it!!! I will have a hard time staying out of the shop until then! Have a Merry Christmas!
Becky
1964 Bambi II
1988 Avion 32S
Old 01-04-2013, 10:39 AM   #35
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Dang! You are all just ever-so-annoyingly talented! I definitely should have paid more attention in high school wood shop!
