08-17-2014, 10:19 AM
1973 Argosy 24
Port Royal
, South Carolina
Kilz original
Any thought's regarding the use of "Kilz Original" on the interior of a 1973 Argosy 24 to eliminate the stains etc.? Good idea, bad idea, terrible idea?
09-07-2014, 08:38 PM
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria
, British Columbia
Howdy, I have never tried Kilz but have had much success with Krylon fusion, just did my end caps yesterday and used it in my bathroom fixtures 5 years ago and those fixtures have taken a lot of abuse and are still going strong. If I did this right I think this will link you to my step by step how to thread... http://www.airforums.com/forums/showthread.php?t=124989
09-07-2014, 10:00 PM
1969 29' Ambassador
brooksville
We had a fire in the bathroom of my ambassador, and ended up pulling almost every thing out, and re painting. We used oil based kilz primer, and then bear exterior paint. I think the most important step is prep. Clean clean clean.. The is a post on the fours where they compare all of the paint options. There was a lot of talk about primers and paints made for plastic. Prob a good idea.
It's been over a year and holding up well in the hot Florida summer.
09-29-2014, 08:27 AM
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria
, British Columbia
Hey Silver flames, that is a great looking floor, nice job ☺
09-29-2014, 08:30 AM
1969 29' Ambassador
brooksville
Thank you! So far so good. It's the Allure sticky side planks. Real easy to install, but have a few seems that have gaps. They are hard to notice due to the color, you have to point them out.
09-29-2014, 09:24 AM
Broadway
, North Carolina
Depends upon the surface and the type of stains.
I use Kilz and Bin for lots of remodeling tasks but lately have been using a new water based primer called Stix from Insul-X, for problem surfaces like pvc, vinyl, and plastics.
Ace hardware sells it here by the quart.
2006 Safari SE FB
2000 F150 4.2L (retired), 2011 F250 6.2L, 2010 ML550, 2000 Excursion 7.3L
Broadway, NC
09-29-2014, 09:32 AM
1977 Argosy Minuet 6.0 Metre
Colorado Springs
The original Kilz is white pigmented shellac, and it works great as a coverup and bonding layer. Shellac will stick to almost anything and almost anything will stick to shellac. Used it on our Minuet about 6 years ago and it is still good. I would recommend just cleaning rather than paint. We had no choice but paint as a previous owner had attacked the interior with a paint brush and vibrant primary colors. I was able to get the paint off but it left a pigmented stain.
Royce (K0RKK) 146.460 simplex
Web page https://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
09-29-2014, 09:48 AM
Broadway
, North Carolina
Originally Posted by Royce
The original Kilz is white pigmented shellac, and it works great as a coverup and bonding layer. Shellac will stick to almost anything and almost anything will stick to shellac. .
If you want a shellac based primer, it is B-I-N by Zinnser. I have found Stix to be better in all cases except one: stopping bleed-thorough of pine knots. Nothing beats shellac for that.
2006 Safari SE FB
Broadway, NC
