Old 11-05-2014, 12:53 PM   #1
Bellevue , Washington
Just got cables collected, but how to remove this?!
2nd owner of my AS, just got a cable collect gadget to manage all the cables. But I want to remove these pre used stick staffs. Seems very strong, any good ideas?
Name:	ImageUploadedByAirstream Forums1415217189.749679.jpg
Name:	ImageUploadedByAirstream Forums1415217203.212903.jpg
shockfly is offline   Reply With Quote
Old 11-05-2014, 01:39 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Remove the basic tape and fitting with a putty knife. The reaming tape will have to be worked off by rolling your finger over it. The last adhesive should come off with alcohol or mineral spirits.
They were designed to stay on.
2004 Excursion 4x4
Old 11-05-2014, 10:59 PM   #3
Thanks, I understand. But I am really not fan of using these permanent style gadgets.
Old 11-05-2014, 11:19 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Take some 'dental floss' wrapped like you are ready for your daily cleanup. Use the taut string as a 'saw' to work back and forth between the wall and the clip base. Will saw off nicely.
Get some 'gorilla tape'... the 200 MPH stuff.. cut in strips wide enough to cover the remaining tape on the wall. Press together firmly.. Add 'heat' from a hair blow dryer.. when warmed up, gently lift the Gorilla tape... it may take a few applications, but the Gorilla tape should lift off the remaining glue...
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-24-2015, 11:16 AM   #5
2005 19' International CCD
Westwood , Kansas
Book. Mkvinpnp
cdross is offline   Reply With Quote
Safety Cables versus Chains Ganglin Hitches, Couplers & Balls 74 05-23-2013 10:01 PM
Charging 12V using TV and jumper cables? Boondocker Electrical - Systems, Generators, Batteries & Solar 21 06-19-2007 09:47 AM
RCA Cables for AV package Tavis76 Electrical - Systems, Generators, Batteries & Solar 3 05-19-2006 07:54 PM
Entry point for phone / other cables? krowsea Electrical - Systems, Generators, Batteries & Solar 8 08-23-2004 10:17 AM
