Old 11-12-2013, 05:01 PM   #1
1975 25' Tradewind
Conifer , Colorado
Is a tile backsplash too heavy?
We have a 1975 Tradewind Land Yacht that we about to renovate and are gathering information. Has anyone used ceramic or glass tiles for a backspash in the galley area? Is the back wall strong enough to support the tile or do we need a backerboard? Would this be too heavy?
dirtman is offline   Reply With Quote
Old 11-12-2013, 05:14 PM   #2
Images: 18
We used smart tiles and you can't tell the difference. It looks like glass mosaic and maybe adds two pounds in weight.
ID:	199844   Click image for larger version
ID:	199846   Click image for larger version
yve79 is offline   Reply With Quote
Old 11-12-2013, 05:22 PM   #3
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Back wall should be aluminum sheet riveted to frame sections, and should be strong enough to support tile/glass backsplash.. Might be more of a challenge dealing with either flexing of sidewall, or expansion/contraction due to heating and cooling.. Those may force you to find flexible mastic or adhesive to make sure backsplash stays in place when you travel, or when trailer in storage if in cold climate...
Condoluminum
Condoluminum is offline   Reply With Quote
Old 11-14-2013, 02:46 PM   #4
crabbey1's Avatar
1976 Argosy 22
Pasadena , California
Images: 33
Send a message via AIM to crabbey1 Send a message via Skype™ to crabbey1
Flex Tile
I tiled over 50% of my bathroom with 1/8" glass tile. I used this company for the grout and adhesive. I stand behind this product 100%. It is called Flex Tile.
The owner of the company created the grout for in ground swimming pools that were subject to large temperature changes. He is also an avid RVer and then started using it in his RVs. Now he markets the product to RVs as well. Anyway, it is somewhat expensive but it will last. Good luck.
Chris
crabbey1 is offline   Reply With Quote
Old 11-15-2013, 03:46 PM   #5
1963 19' Globetrotter
Moline , Illinois
Questions
I looked at the flextile site and it sounds like you could use most any ceramic or glass tile subject to size limitations , is that true? Also ,would you only need the special grout and scrubbers since his 100% silicone is probably just like any other brand ? Looks like something neat to do.
63air is offline   Reply With Quote
Old 11-19-2013, 05:56 PM   #6
Peter77's Avatar
1973 31' Sovereign
Edmonton , Alberta
I used a flexible backed stainless steel tile
ID:	200321   Click image for larger version
Peter77 is offline   Reply With Quote
Old 11-19-2013, 09:59 PM   #7
crabbey1's Avatar
1976 Argosy 22
Images: 33
63Air = They recommend that you use only their product. I would take their advice. Make sure to get a ton of their special scrubbers. You will need them. Also, you could probably do with half the amount of adhesive that they recommend...
Old 11-19-2013, 10:00 PM   #8
crabbey1's Avatar
1976 Argosy 22
Images: 33
Peter77 = Where did you get those at? Very cool look!
Old 11-19-2013, 10:14 PM   #9
2004 28' Classic
austin , Texas
We used the same tiles as Peter77 in our bath and to replace mirrors on the upper cabinet doors in our Classic. Got them at Lowes. They come as a peel and stick sheet. Looks great as a kitchen backsplash...I may try it.
ID:	200341   Click image for larger version
Ntex is offline   Reply With Quote
Old 11-19-2013, 10:20 PM   #10
crabbey1's Avatar
1976 Argosy 22
Images: 33
You guys have some very steady and accurate knives...
Old 11-19-2013, 10:22 PM   #11
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Home Depot carries the metallic tiles in several colors and sizes. I went with the champagne subway tiles for the backsplash in the path.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 11-20-2013, 06:31 PM   #12
Moline , Illinois
I've been thinking about the peel and stick metal also , very good look!
Old 11-20-2013, 06:36 PM   #13
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
OOOOH pretty! Shine!
They aren't real glass? What are they? BTW, Love the blind too!
Old 11-21-2013, 07:13 PM   #14
cdmagda's Avatar
Images: 51
Sounds heavy...would Wally do that?
cdmagda is offline   Reply With Quote
