Old 11-08-2015, 09:12 AM   #1
1972 27' Overlander
Broussard , Louisiana
Interior walls and ceiling cleaning
We purchased a 1972 Overlander. The interior walls and the ceiling need to be cleaned. Can I use Dawn detergent to clean them? Any suggestions?
Olegus is offline   Reply With Quote
Old 11-08-2015, 10:57 AM   #2
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Those vinyl covered walls are very durable. You can use anything you have on hand to clean them. My favourite thing to use is bathroom sprays with bleach, stuff like Sudsing bubbles with bleach or Tilex mildew remover, that sort of thing. Just because I like to test the limits of things I did a test on a scrap of my 69's vinyl wall to see what kind of abuse the walls could take and nothing I threw at them hurt. I've used comet, pinesol, Tilex, paint thinner, scrubbing bubbles and hell even my house house carpet cleaners hand held rotary furniture attachment on the walls, no damage. Another awesome thing to know about is citrus based glue removers. Sometimes the walls in these old trailers can get sticky, very sticky...That can come from years and years of build up from cooking in the trailer and smokers from days gone by. I found that spraying citrus based adhesive remover on the wall and scrubbing it in to the textured finish with a nail brush, leaving it sit 60 seconds to break the grease down and wiping off with a paper towel works really well. Repeat as needed until its not sticky.
Enjoy your new trailer :-)
thesignlady is offline   Reply With Quote
Old 11-08-2015, 11:09 AM   #3
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
I used TSP and dish soap after a bathroom fire. Worked well. Still had to prime and paint.
Silverflames is offline   Reply With Quote
Old 11-08-2015, 07:02 PM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I used a hardware store product called "krud kutter". It is just a stronger spray on cleaner similar to 409 and the like. It worked quite well for me.
David
Old 11-08-2015, 07:47 PM   #5
1972 27' Overlander
Thanks everyone. I used Dawn and warm water. It's better than it was, but definitely will need to clean again and eventually painted.
Old 11-08-2015, 09:52 PM   #6
TWaugh's Avatar
1969 25' Tradewind
1971 18' Caravel
Images: 8
Once you get it clean and if you decide to paint it you might want to get a can of Krylon Fusion spray paint (True Value, Hobby Lobby, etc.) It adheres wonderfully to the vinyl and covers thoroughly (thats one of the materials its made for without any extra prep such as sanding or scuffing the vinyl) and it comes in a variety of colors and some different textures. I chose the Dover White satin finish and it looks wonderful.
https://www.google.com/url?sa=t&rct=...06923889,d.eWE
Tom
Res nolunt diu male administrari.
WDCU Unit #170
Air #7085
TAC VA-4
WBCCI #2641
VAC
71 Caravel
69 Tradewind
My YouTube Channel
TWaugh is offline   Reply With Quote
Old 11-09-2015, 06:09 AM   #7
r carl's Avatar
Lin , Ne
Simple Green works great too.
Old 11-09-2015, 07:47 AM   #8
1971 31' Sovereign
Indian Wells , California
Marine Clean from the POR15 guys and a stiff brush cleaned mine well.
CraigCA is offline   Reply With Quote
Old 11-09-2015, 10:10 AM   #9
1971 31' Sovereign
Temple , Texas
cleaning walls
We just cleaned our walls and ceilings on our '71 Sovereign this past weekend. We used a combination of Tilex mildew remover and a Mr. Clean magic eraser. The walls look like new. Amazing!
TxDave is offline   Reply With Quote
Old 11-09-2015, 10:50 AM   #10
1973 29' Ambassador
Vancouver , Washington
Finish on the walls
After you get them clean use pledge floor cleaner on a damp rag to shine and remove stickiness. Works great
Amybeth is offline   Reply With Quote
Old 11-09-2015, 11:13 AM   #11
1972 27' Overlander
Colorado Springs , Colorado
I used Awesome from Dollar stores then followed by Mr Clean Magic Eraser (light pressure when using). Cleaned up our recently acquired 72 Overlander quite nicely. Interior hadn't been done since new.
jvannamee is offline   Reply With Quote
Old 11-09-2015, 12:13 PM   #12
NOAZRK
NOAZRK2690's Avatar
2004 34' Classic S/O
Kutztown , Pennsylvania
If all else fails, pick up some Spray 9, available at most home centers. Here's the trick. Put it on a dry surface, agitate with a wet brush or piece of damp towel. Works great for the white raised letter tires too. Often used in hospitals to kill like 99.9% of germs. I mixed a batch with about 70% spray 9, 5% bleach and 25% water then sprayed it on the material side walls of my 2004 AS. Let it work for a while, scrub with an dampened old white wash cloth, left it dry. The mix had no effect on adhesion of the material to the wall and cleaned everything like new. Worked great on the white vinyl ceiling also, but overhead just dipped the cleaning rag in the solution rather then to have a spray mist flying around. Rubber gloved recommended.
NOAZRK2690 is offline   Reply With Quote
Old 11-10-2015, 07:54 AM   #13
1992 29' Excella
1972 27' Overlander
Wakefield , Rhode Island
Be careful with Spray 9. It will take powder coating and paint right off any metal. (Watch out for your trim pieces especially.)
For additional discussions and suggestions on dealing with sticky walls, do a Google search on Airforums.
Good luck. Cleaning the walls and ceiling and getting rid of the stickiness is a royal pain. But you'll have strong arms when you're done!
msimon is offline   Reply With Quote
Old 11-10-2015, 01:02 PM   #14
1965 30' Sovereign
1969 23' Safari
Redgranite , Wisconsin
Greased Lightning
I used Greased Lightning to clean the vinyl walls in my 65 after hearing it recommended years ago by fellow streamers. I bought several bottles at Ace and only used a portion of one in a 30 footer. It worked that well.
NOTE: it contains acid. Ventilate well and a respirator would help. Also keep away from aluminum and stained wood surfaces. It didn't hurt my overhead door handles but did bleach my front console wood where overspray landed.
Simply spray on and wipe the gross brown dripping stuff off. Repeat as needed. I did not experience sticky surfaces before or after but have used Future floor wax on my door to try it. No difference in color or tackiness after 3 years.
65Streamer is offline   Reply With Quote
Walls and Ceiling Cleaning curnes Upholstery, Blinds, Walls & Interior Finishes 22 01-08-2016 06:12 PM
Adding wood paneling to interior walls/ceiling CTdave2000 Upholstery, Blinds, Walls & Interior Finishes 2 04-01-2015 08:42 PM
Black Spots on Interior Walls, Ceiling Billie Bob Upholstery, Blinds, Walls & Interior Finishes 4 07-31-2010 09:33 AM
Cleaning Fuzzy Interior Walls?? Steve Heywood Upholstery, Blinds, Walls & Interior Finishes 21 09-19-2006 08:42 PM
Painting Interior walls, Ceiling DJbyRequest General Interior Topics 37 05-29-2005 09:51 PM
