Old 03-07-2014, 05:11 PM   #1
1966 22' Safari
tucson , Arizona
Interior wall/ceiling covering
Has anyone tried to cover the walls/ceiling in Formica or bending plywood (comes in many veneer types) and glued it to the ribs instead of using rivets or screws? Not seeing the fastener type would be quite nice.
1966air is offline   Reply With Quote
Old 03-07-2014, 05:39 PM   #2
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
check out the interior pictures thread.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 03-16-2014, 11:45 PM   #3
Install bendable plywood with countersunk screws into ribs as glue will not hold at ceiling until dry.
Fill countersunk screws with matching sized, matching wood species of wood dowels as wood plugs to hide screws. Sand glued wood plugs to be smooth with plywood.
AirBambi is offline   Reply With Quote
Old 03-17-2014, 12:03 AM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
The thing that sucks about glue, is the inability to reasonably disassemble.
Old 03-17-2014, 05:40 AM   #5
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Asa retired carpenter of 25+ years i have always liked the look of a stainless screw through a chrome finish washer as an option for an exposed fastening system. In my opinion it works well with the riveted concept of the airstream where there is a certain aesthetic beauty to seeing how the rig is constructed as part of the overall feel.
mayco is offline   Reply With Quote
Staining on white fabric wall covering on 2005 bambi's Kans Upholstery, Blinds, Walls & Interior Finishes 7 08-10-2013 08:16 AM
Shower wall covering peeling ?? Solution ?? polarlyse Sinks, Showers & Toilets 6 02-06-2012 08:08 AM
No Factory Floor Covering Intrepid Repairing/Replacing Floor &/or Frame 2 09-20-2011 07:48 AM
Ceiling/wall covering easy sawyer Windows, Doors, Locks & Vents 5 05-27-2011 11:09 AM
Wall Covering Pictures Roadrunner Upholstery, Blinds, Walls & Interior Finishes 7 05-19-2011 10:50 AM
