Old 10-21-2017, 05:15 PM   #1
1968 26' Overlander
Loomis , California
Interior Skin Replacement
We purchased a 1968 overlander airstream. The person before us, THREW AWAY all of the interior skins!
How to we create the inside skins?!? We have tried tracing paper, we have tried cardboard, we have tried cut, fit, cut again. Any suggestions would be greatly appreciated!!
Thank you,
MT
Mtiner is offline   Reply With Quote
Old 10-21-2017, 06:20 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Just to be clear:
Are we talking about the aluminum sheets that make up the inner skin of the trailer or the stuff that goes on top of those aluminum sheets?
uncle_bob is online now   Reply With Quote
Old 10-21-2017, 06:29 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Welcome from Colorado. You have purchased a worthy project trailer. Many folks prize the 68 model year as it is the last year of the old body style. The 69s were completely different.
The interior skins are easier than the exterior skins. You now have a chance to repair exterior joint leaks, rewire and replumb the trailer, and then improve the insulation. A well renovated 68 Overlander is worth quite a bit.
I kinda hope you have the fiberglass molded interior "end caps". Reskinning the spherical shaped end caps is a rear bear. There are "kits" for this with the aluminum pre-cut. Airstream went to molded end caps cause it's so much easier.
Toward the bottom of Airstream Forums you will find the Airstream Knowledge Base. These are forums by year and model of Airstream. Click on Overlander, and click on your year range. You can read a lot of interesting renovations and repairs directly related to your Overlander.
Interior skins can be replaced. Folks on these Forums have done it. You can use the google search function to find threads related to it. Here is a search I did that ought to get you going.
replacing interior aluminum skins site:airforums.com
David
Old 10-21-2017, 11:01 PM   #4
1968 26' Overlander
Loomis , California
Hi
Just to be clear:
Yes- the aluminum sheets not the vinyl that is sprayed on.
Old 10-22-2017, 09:31 AM   #5
Half a Rivet Short
Hi
As mentioned above, the rounded skins are a bit of a pain to fabricate yourself.
Good luck !!!
Old 10-22-2017, 06:32 PM   #6
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Actually the vinyl coating on the interior skins of vintage trailers is quite nice. The 66 Trade Wind vinyl held up very well through the years. It is easy to clean and very tough stuff. The 75 Overlander also appears to be good stuff although I don't like the pattern as well as the 66. I wonder if the vinyl wasn't laminated onto the sheets of aluminum?
Several interior decor in new Airstreams have just aluminum skins for that shinny look.
David
Stripping Interior Skin. Need a replacement part SushiRV Upholstery, Blinds, Walls & Interior Finishes 2 05-04-2017 11:13 AM
interior skin scrap for exterior skin patch? badger Ribs, Skins & Rivets 1 06-12-2010 07:56 AM
Interior Door Skin Replacement Sunset Coast Doors & Locks 0 03-10-2008 07:43 PM
Sealing exterior skin panels with Lizard Skin BB 55 Bubble Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 11-21-2006 04:50 PM
Re-attaching cabinets to the interior skin. Andy R Cabinets, Counter Tops & Furnishings 5 04-07-2002 02:54 PM
