Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum
Old 07-15-2015, 01:16 PM   #1
1974 25' Tradewind
Waverly , Ohio
Interior Paint
We are the proud new owner's of a 1974 Airstream Land Yacht Tradewind (my very first RV)! It's definitely in need of a full interior restoration and I'm wanting to paint the walls. The walls are rough-like, I'm not sure of the material. Any suggestions of what kind of paint I need to use on the walls and cabinets?
Thanks so much!
kmrenner17 is offline   Reply With Quote
Old 07-17-2015, 11:46 AM   #2
Highland Village , Texas
Prep is your key to success. Clean the surface well making sure to remove any oil or grease. You can use TSP found in the paint department prior to applying any paint. I used a good primer and then a good latex paint in your choice of color from Lowes or Home Depot. Mine has held up very well. We replaced all of the cabinets so I did not paint those.
Hope this helps and good luck.
dleetexas is offline   Reply With Quote
Old 07-17-2015, 09:03 PM   #3
Beaker63's Avatar
1963 16' Bambi
Stevens Point , Wisconsin
Hey KM.
Did the same, clean with TSP, use a stain blocking oil base primer then roll on any color of latex paint. Note- rollers don't work on the curved corners. I filled and sanded any defects or unused rivet holes with auto body filler before painting.
Tim
Beaker63 is offline   Reply With Quote
Red numbers paint? hand paint? Zstream Clearcoat, Exterior Paint & Trim 2 10-02-2008 11:35 AM
to paint or not to paint roof Angel73 Clearcoat, Exterior Paint & Trim 18 03-31-2008 07:29 AM
To Paint or Not to Paint My Dashboard Chaplain Kent General Interior Topics 8 02-23-2006 07:41 AM
Paint stovetop with high temp paint? scooterpie Stoves, Ovens & Microwaves 4 02-19-2006 03:47 PM
paint or not paint PeterH-350LE Airstream Motorhome Forums 15 01-22-2003 09:27 AM
