Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum
Old 08-03-2008, 03:17 PM   #1
codybear's Avatar
1964 22' Safari
SACRAMENTO , California
Images: 315
Interior or exterior application?
Some of our rivets have popped out inside our safari..any recommendations for the Olympic 5/32 ones that I see at Vintage Trailer?..how 'bout the optional washers, good idea?..the ones that are currently in the seams are 1/8..thnx
codybear is offline   Reply With Quote
Old 08-03-2008, 03:23 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
You probably won't want to use the Oly's for interior replacement, they have a much bigger head and splay out inside the wall like a toggle bolt; overkill IMHO. I would use the white 1/8" and if they pop again go up to the 3/16" and paint the heads with model paint, nail polish or white out I have found that if a rivet pops it means that it was installed improperly, the hole was drilled poorly (wallowed) or you have another issue that needs to be addressed.
Aaron
WBCCI #XXXX AIR #2495
Old 08-03-2008, 03:24 PM   #3
Your popping interior rivets from a cause.
Either your axle is bad, and/or your running gear is out of balance.
Olympic rivets are for the exterior only.
Also using Olympic rivets with the washers, on the exterior, is a guarantee of having water leaks, and is recommended by those that know little to nothing of an Airstream's behavior when towing.
Regular Olympics are used on the exterior, along with Vulkem sealer.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-03-2008, 03:30 PM   #4
codybear's Avatar
1964 22' Safari
Images: 315
Thnx guys for the informative info!
paula
application temperature for vulkem bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 02-25-2007 09:35 AM
What to do with this exterior silvrtwinkie Cleaning, Stripping & Polishing 40 05-11-2005 12:19 PM
possible interior exterior damage nu2argosy All Argosy Trailers 4 01-13-2004 04:51 PM
Sealant Products - Exterior & Interior Cat Leaks - Weatherstrips, Gaskets, Caulks & Sealants 21 02-12-2003 10:00 PM
Exterior Layjhay Cleaning, Stripping & Polishing 2 02-07-2003 08:23 AM
