Old 05-15-2015, 04:17 PM   #1
2003 22' International CCD
Fredericksburg , Texas
Insulation
When replacing the insulation with new material should I try to get some without the paper vapor barrier or use it with the vapor barrier next to the outside skin?
jasfox is offline   Reply With Quote
Old 05-15-2015, 05:17 PM   #2
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
I would not recommend using the vapor barrier. The aluminum skin will serve that purpose. The concern would be that if for any reason you did get any moisture (a leak around a rivet, window trim, clearance light etc...) in between the skin and the kraft paper it would be trapped there and could potentially cause mold. IF you cannot find any unfaced insulation simply peel the kraft paper away from the fiberglass and discard it.
Gregsch is offline   Reply With Quote
Old 05-15-2015, 06:41 PM   #3
batman's Avatar
1964 22' Safari
modesto , California
Try, Johns Manville it is blue fiberglass and comes in sheets or rolls with or with out backing. They carry it at Lowe's.
The best part is they do not use formaldehyde like the pink stuff.
You might also think about using Prodex roll insulation as well.
There are many threads on the subject and just as many opinions as to what insulation is best.
I used a combination of Johns Manville Fiberglass and Prodex with taped panels. We are very comfortable camping in snow and cold as well as Death Valley heat.
-Dennis
batman is offline   Reply With Quote
Old 05-15-2015, 08:05 PM   #4
cameront120's Avatar
1972 25' Tradewind
You don't want any organics (paper) in a condensation prone structure. I would also argue against fibreglass insulation which holds any moisture that it is exposed to, leading to a deterioration of your already low r-value. I would recommend a rock wool insulation like Roxul. Mineral wool is hydrophobic, so will not retain an water that might come in contact. As for vapour barrier, your aluminum skin is already serving that purpose.
North Vancouver, BC
Old 05-15-2015, 10:23 PM   #5
Many thanks for the suggestions. I think I know how to proceed.
Old 07-03-2015, 08:49 AM   #6
Westminster , Colorado
I am using Henry Solar Flex, then prodex, then bonded logic UltraTouch insulation (it's really awesome stuff!!). Their website says the product I'm using is 2", but when I spoke with customer service, she said it's about 1.5" If there is room, I'll put in another layer of prodex.
Rachael
painterfam is offline   Reply With Quote
Does old fiberglass insulation equal new fiberglass insulation? Petethefeet General Interior Topics 7 11-14-2010 12:16 PM
Glass windows; insulation smallfry Windows & Screens 5 01-10-2003 05:15 PM
is the insulation flammable ? oldvws General Interior Topics 3 12-31-2002 11:12 AM
Insulation Cat General Interior Topics 6 11-26-2002 06:31 AM
Pipe insulation niftypkg Plumbing - Systems & Fixtures 1 09-22-2002 09:34 PM
