Old 08-02-2015, 09:39 AM   #1
2009 25' FB Flying Cloud
Old Orchard Beach , Maine
Inside interior
What's the best product to clean all of the aluminum inside, with the least effort, include procedure? Thanks!! Gordy
gordymurphy4 is offline   Reply With Quote
Old 08-06-2015, 05:04 PM   #2
1972 27' Overlander
puyallup , 98373
hello gordy , im working on the same thing and I found the best reference on youtube . type airstream shine and cleaning and they show you all the products to use and walk you through it step by step. its 7mins long. good luck !
firstremodel is offline   Reply With Quote
Old 08-06-2015, 06:54 PM   #3
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
It all depends on what you are going to do with the interior, and what it is like now... If you have a newer AS then you might see what the factory recommends. If you have vintage, like we have... we scrubbed down the interior walls with 409 and a green scrubbie, rinsed and hubby painted with new zolotone. Love it! zolotone is nearly indestructible!
Mrs. NorCal Bambi traveling in S Tardis ~ from the Great State of Jefferson!
My blogs: http://yrekahistory.blogspot.com
http://siskiyoucountycamping.blogspot.com
http://campingalongi-5.blogspot.com/
CaddyGrn is offline   Reply With Quote
Moisture inside interior window trim - normal? SCOTTinNJ Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 09-28-2014 07:57 AM
Inside hot water heater cover davidz71 Water Heaters, Filters & Pumps 12 03-24-2008 08:11 PM
deadbolt with inside twist style lock cindy Doors & Locks 4 10-16-2002 08:58 PM
Inside door handle for a 1984 International Bennie 1980-1984 International 0 08-06-2002 08:37 PM
inside light lens' how to remove to clean Paul Daugherty Mechanics Corner - Engines, Transmission & More... 12 04-25-2002 10:51 PM
